How do I access a file in a plugin's jail?
CraftyClown
Hi all,
The developer of a plugin I use 'Mylar' has just asked me if I can provide him with the Mylar.db file so he can help me troubleshoot an issue I am having.
Unfortunately with my limited knowledge of Unix, I'm not sure how to access that file and send it to him.
Can anyone help?
Cheers
CraftyClown
Thanks for that.
Unfortunately, part of what I am having difficulty with, regarding accessing files via shell, prevents me accessing via SSH as well.
'To start the SSH service, look for the following line in that jail’s /etc/rc.conf:'
What exactly am I supposed to be doing here?
Sorry, my knowledge of Unix is primary at best :(
D
dlavigne
Guest
You have to open the file in an editor to make the change. Try using the easy editor: ee /etc/rc.conf.
CraftyClown
All I get when I run 'ee /etc/rc.conf.' from my plugins jail is the below screenshot
Something doesn't seem right
D
dlavigne
Guest
OK then, insert this line:
sshd_enable="YES"
and save the change.
CraftyClown
Okey dokey, so after a fair amount of tinkering about, I can now SSH into my Freenas box using Putty
I have literally no idea what to do next :D
Jailer
Not strong, but bad
It's easier to just copy out the file you need using an FTP client.
D
dlavigne
Guest
Try winscp, it has a nice double-pane graphical view where you can drag and drop files between systems.
Jailer
Not strong, but bad
Would you mind explaining how I would do that Jailer?
You've already got SSH turned on so all you need is an FTP client. Use the SFTP protocol and log in with your root credentials and browse to the directory where the file is located.
CraftyClown
Thanks dlavigne and Jailer
I have managed to grab the file I was after via Filezilla :)
One last question. When I SSH in to my Freenas box, it defaults to showing a folder called root, which only seems to contain the contents of the plugin jail I added the ssh commands to
I can still see all the other folders and files however, if I go up one level. Is this normal behaviour? and what would happen if I followed the same process with other jails? would their contents all end up in the same 'root' folder
I'm also wondering what the point of adding the new user was? (as suggested in the Freenas manual) as I needed to ssh in as root
Jailer
Not strong, but bad
You're better off logging in as a user (SSH) and switching to root after you log in. Logging in as root locally isn't a big deal but I wouldn't suggest enabling it for remote log in.
That's standard behavior for logging in via FTP BTW.
