- Oct 29, 2016
deduplication needs GOBLOADS of RAM. as in, don't bother considering it until you have, iirc, 128GB, or maybe 256GB. since you are balking at 32GB and 64GB....this is not an option.I need to seriously evaluate deduplication...
poorly setup dedup can make your pool unusable, and require a destroy/rebuild of the pool, since one does not simply disable dedup - once enabled, and data is written, the deduped data will exist until all of it is deleted and any snapshots are deleted AND any referenced data is deleted.
home 10gbe networks are very doable. you don't need a 10gbe router to get 10gbe on the LAN.
