I rely on cloud, but I use encryption, which means that cloud sync is not for me anyway, unless I encrypt the data before.
For cloud encryption, I use Rclone.
It's a very powerful tool for that but not easy to handle at first.
I actually need to buy another machine to develop properly, hence, I could use that with TrueNAS and run VMs in it, but it's not the same as running VMs on Linux, right?
Having extra services on the NAS to serve the local LAN should be safe. Security issues come with exposing the NAS to the wider world. Use a VPN to access the NAS and its services remotely.
You can run publicly accessable services in jails and VMs. The security implications are no different than with any other virtualisation platform. Many users seem to run Nextcloud in a jail.
It seems I don't know quite a lot of this product then :D .Have you looked at what is possible with TrueNAS SCALE?
It should fit your needs I think: https://www.truenas.com/truenas-scale/#_
It's based on Debian stable and you can run Docker, KVM, Kubernetes...
3. Is TrueNAS Scale actually the same product as TrueNAS? It runs on Debian, but is there any reliability compromise?
Note that you can run a Linux VM on TrueNAS CORE as well…It seems I don't know quite a lot of this product then :D .
That's really cool, I won't have issues to move my VMs.
Not optimal but serviceable for a first try at a small NAS if the NIC is Intel and not Realtek. Some Ryzen boards do support ECC unofficially.The only thing is that my current hardware is the following:
- AMD 1600
- MSI motherboard 4x SATA, 1 M2, 1 eth
- 32GB gaming RAM, not slow ones :D , but they are not ECC..................
- 1x2TB M2
- 256GB SSD for boot
- Decent case, but I can buy a better one
It's an issue for components, not for the motherboard as a whole, or its maker.2. Driver issues for MSI?
The ZFS part is supposed to be on par, but obviously SCALE does not have the same amount of field testing as CORE.3. Is TrueNAS Scale actually the same product as TrueNAS? It runs on Debian, but is there any reliability compromise?
Yes I know, but the migration could have some issue, for example, config issues...Note that you can run a Linux VM on TrueNAS CORE as well…
Unfortunately I have Realtek, as every gaming board...Not optimal but serviceable for a first try at a small NAS if the NIC is Intel and not Realtek. Some Ryzen boards do support ECC unofficially.
The lack of ECC is not redibitory, but if you're buying to build it's indeed better to go for ECC.
Not a big issue, just get yourself a used Intel NIC and you are fine.Unfortunately I have Realtek, as every gaming board...
That's right, I forgot that I needed only one port, not many like in a switch :D , it's gonna be cheapNot a big issue, just get yourself a used Intel NIC and you are fine.
High Availability | No |
High Availability | Yes |
RAIDZ1 means you can lose one disk and still be good. Lose two and the data is toast. RAIDZ2 means you can lose two disks and still be good. Lose three and the data is toast.- 3 disks in RAIDZ1 (I think I can have 2 drives failure with this type of RAIDZ, but only one drive is used for the active pool...)
From the documentation: A RAIDZ1 uses one disk for parity while all other disks store data. A RAIDZ1 requires at least three disks.
It seems strange to me that it uses 2 disks for data and only one for parity... Does it mean that I can lose 2 disks actually? (one from the pool and one of parity???)
that seems really high. that sounds more like the yearly power costs, not monthly, unless maybe you are running prime95 all month?The cluster will cost me 22 pounds of energy per month average
Are you aware of electricity prices in Europe? 50 cents per kWh is not a bad price these days here in Germany. And from what I have read it is not very different in the UK.that seems really high. that sounds more like the yearly power costs, not monthly, unless maybe you are running prime95 all month?
