Engine1992
- Dec 25, 2021
Hey! I have two questions:@Norumen
Here is what I used.
Make sure to use a location on your data pool as a working directory, don't use any system directory.
Use wget to get the ova file:
Code:wget https://github.com/home-assistant/operating-system/releases/download/6.6/haos_ova-6.6.ova
Extract the ova file using tar:
Code:tar -xvf haos_ova-6.6.ova
Convert the vmdk to a raw image file, I had to use the full working directory for the source:
Code:qemu-img convert -f vmdk -O raw /must include full working path/home-assistant.vmdk hassos.img
Create a Zvol using the TrueNas Scale GUI - Be sure to make it large enough for dd to complete, I used 35 Gib.
Use dd to write the image file to your zvol
Code:dd if=hassos.img of=/dev/pool/yourzvolhere
Create a virtual machine using the gui and attach the zvol you just created as the hdd
Enjoy Hassos. Hope this helps.
1. I tried to
dd if=hassos.img of=/yourzvolhere (my name of zvol)
2. What do U mean when you text: "must include full working path"? I just type
qemu-img convert -f vmdk -O raw home-assistant.vmdk hassos.img
I am a beginner to using the console, so please be understanding and patient ;)
