Is there a way, either with the official or Truecharts Home assistant app, to upload a backup file?
Having just installed Home assistant in TrueNAS scale (using the default options), then logging in with a new user account, navigating to "Settings > System > Backups", there doesn't seem to be a way to upload the backup file which I saved from my existing install (which is a 'supervised' install type, running in a VM on a Win 10 box).
On my existing VM install, if I go the "Settings > System > Backups" there are 3 dots on the top right, which allows "Upload backup", but the 3 dots aren't there on the TrueNAS Home assistant installation. I've tried both the native & Truecharts versions.
EDIT: On further reading, I think this just isn't an option for docker/kubernetes-type installs of HA, given it's not a supervised version of HA.
The way around this will be to install HA in a VM under TrueNAS.
