Hi
I have been using Truenas Core quite for some time virtualised in my homelab to present datastores to my vmware hosts which has been working fine for years.
I now wanted to build my own storage NAS. I have been using synology quite for some time now. But though lets bite the bullet and build a truenas server.
This server will be used to run PLEX, Backup repository for VEEAM, VMs
I plan to use a 24 bay case - 12 bays with 20TB Seagate EXOS, this will hold my media for PLEX, veeam backups etc and general files. I was going to populate the other 12 with SSD 870 EVO at some point and then some NVME quad cards. Some of the SATA SSDs could be used as cache for the spinning drives.
Below is my parts list as of today - still gathering bits
CASE - CASE
MB - SuperMicro - X10DRi
CPU - 2x Xeon E5 2667v4
RAM - 8x 2133Mhz ECC 32GB Modules
GPU - Quadro P2200
HBA - Saw this - HBA -LSI Logic Controller Card IT Mode 9305-24i 24-Port SAS 12Gb/s PCI-E 3.0
DRIVES - 12x 20TB Seagate EXOS start with then probably add some Samsung EVO 870
NIC - Mellanox Connectx4 25GBe dual sfp+
PCI - 4 slot NVME Card
PSU - Corsair AX1500i
CPU COOLER - Noctua NH-D9DX i4 3U
I noticed this motherboard has 2x EPS connectors so I got a bigger PSU which supported this and was on sale.
I went with this build as I wanted the PCIe Lanes and the board supports bifurcation which is good.
My knowlege around HBA cards is very limited but I saw this card mentioned in a few forums so thought check it out.
Would the following HBA card work with my setup straight out the box? It does state it is in IT mode which i know that is required to work with Truenas.
Any help is much appreciated.
Thanks
CASE - CASE
GPU - Quadro P2200
Thanks
