Help with finding rack case for nas
r4ptor
So its finally time to build my new NAS, it's been on my to-do list for a while now.
I have everything that i need except for the chassis, I cant find "the one" that i want.
Here is what I'm looking for:
- 2-4U Rackmountable
- Fit in a 600mm deep rack
- Takes mATX motherboard or smaller
- ATX PS2 power supply
- 12-hotswap, already built in or through caddies
- Takes 3,5" drives.
I also like to add that JBOD chassis works as well, but the depth still apply.
Does anyone have any recommendation base on my list, or at least close to it?
Chris Moore
Chris Moore
Lets say that i need a case around 600mm deep
What 550 isn't close enough to 600? It isn't that granular. You are lucky to find ONE server that short, most are much deeper.
I have a three servers racked at work that hang out the back of a 914mm deep rack and the majority of the servers are between 700 and 900 mm.
Chris Moore
Inxsible
If you are looking for cheaper rack cases/chassis then these might help.
They also have options where they sell chassis with PSUs. Look around.
I notice that you are in Sweden. So the shipping might be expensive from USA.
Norco is another that makes rackmount chassis.
In fact this looks very similar to a Norco 4U
