HELP! Upgrade from FreeNAS 11.3-U5 to TrueNAS 12.0-U2.1, attempted to upgrade GELI encrypted pool, it failed. Cannot unlock nor import pool
Voltrix
Hello fellow NAS'ers!
Three days ago I upgraded from FreeNAS 11.3-U5 to TrueNAS 12.0-U2.1 and attempted to upgrade the GELI-encrypted pool.
The OS upgrade was successful. So, I proceeded to also upgrade the raidz2-0 pool.
I do not recall there being a problem with the pool's upgrade. I do recall that I was able unlock the pool at least once and resolved an issue with a jail\iocage.
A few reboots later, unrelated to the iocage problem, I found myself with a pool that I could not unlock.
It was still visible in the GUI under Storage --> Pools. So, I did an Export\Disconnect (UNCHECKED "Delete configuration of shares that used this ?" and ensured UNCHECKED "Destroy data on this pool?") in the hopes of re-importing it. I also downloaded key before confirming.
(Yes, I do have passphrase and I saved the encryption key).
When, tried to Add --> Import an existing pool --> Yes, decrypt the disks --> and tried to select the disks but only one of the four disks was listed!
This is when panic set in. :oops:
Rebooted back to FreeNAS 11.3-U5, tried to import an existing pool and, again, saw only one of the four disks.
Performed S.M.A.R.T tests, no problems.
Also, upgraded mobo's BIOS. Still, no change.
Rebooted to TrueNAS 12.0-U2.1 and still could import an existing pool using GUI.
Started reading... And spent many hours reading many sites and posts.
Tried looking for problems as best as I could... eventually coming to a oh-I-hope-not realization (see the end).
Used many commands to look around and look at things:
camcontrol devlist:
root@vtxnas1:~ # camcontrol devlist
<ST8000VN0022-2EL112 SC61>         at scbus1 target 0 lun 0 (pass0,ada0)
<ST8000VN0022-2EL112 SC61>         at scbus2 target 0 lun 0 (pass1,ada1)
<ST8000VN0022-2EL112 SC61>         at scbus3 target 0 lun 0 (pass2,ada2)
<WDC WD80PURZ-85YNPY0 80.H0A80>    at scbus4 target 0 lun 0 (pass3,ada3)
<ST10000VN0008-2JJ101 SC60>        at scbus5 target 0 lun 0 (pass4,ada4)
<AHCI SGPIO Enclosure 2.00 0001>   at scbus9 target 0 lun 0 (pass5,ses0)
root@vtxnas1:~ #
geom disk list:
root@vtxnas1:~ # geom disk list
Geom name: nvd0
Providers:
1. Name: nvd0
   Mediasize: 250059350016 (233G)
   Sectorsize: 512
   Mode: r1w1e2
   descr: Samsung SSD 960 EVO 250GB
   lunid: 0025385381b2f992
   ident: S3ESNX1K302721Z
   rotationrate: 0
   fwsectors: 0
   fwheads: 0
Geom name: ada0
Providers:
1. Name: ada0
   Mediasize: 8001563222016 (7.3T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
   descr: ST8000VN0022-2EL112
   lunid: 5000c500a467fd91
   ident: ZA18TS5R
   rotationrate: 7200
   fwsectors: 63
   fwheads: 16
Geom name: ada1
Providers:
1. Name: ada1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
   lunid: 5000c500a4683f57
   ident: ZA18VL80
   rotationrate: 7200
   fwsectors: 63
   fwheads: 16
Geom name: ada2
Providers:
1. Name: ada2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
   lunid: 5000c5007441b14a
   ident: ZA169QV9
   rotationrate: 7200
   fwsectors: 63
   fwheads: 16
Geom name: ada3
Providers:
1. Name: ada3
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
   descr: WDC WD80PURZ-85YNPY0
   lunid: 5000cca263c7d159
   ident: R6GK648Y
   rotationrate: 5400
   fwsectors: 63
   fwheads: 16
Geom name: ada4
Providers:
1. Name: ada4
   Mediasize: 10000831348736 (9.1T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   descr: ST10000VN0008-2JJ101
   lunid: 5000c500c800f044
   ident: ZPW0C4FP
   rotationrate: 7200
   fwsectors: 63
   fwheads: 16
gpart show:
root@vtxnas1:~ # gpart show
=>       40  488397088  nvd0  GPT  (233G)
         40     532480     1  efi  (260M)
     532520  487864600     2  freebsd-zfs  (233G)
  488397120          8        - free -  (4.0K)
=>         40  15628053088  ada0  GPT  (7.3T)
           40           88        - free -  (44K)
          128     18874368     1  freebsd-swap  (9.0G)
     18874496  15609178632     2  freebsd-zfs  (7.3T)
=>         40  15628053088  ada1  GPT  (7.3T)
          128      4194304     1  freebsd-swap  (2.0G)
      4194432  15623858696     2  freebsd-zfs  (7.3T)
=>         40  15628053088  ada2  GPT  (7.3T)
=>         40  15628053088  ada3  GPT  (7.3T)
root@vtxnas1:~ #
gpart show -r:
root@vtxnas1:~ # gpart show -r
         40     532480     1  c12a7328-f81f-11d2-ba4b-00a0c93ec93b  (260M)
     532520  487864600     2  516e7cba-6ecf-11d6-8ff8-00022d09712b  (233G)
          128     18874368     1  516e7cb5-6ecf-11d6-8ff8-00022d09712b  (9.0G)
     18874496  15609178632     2  516e7cba-6ecf-11d6-8ff8-00022d09712b  (7.3T)
          128      4194304     1  516e7cb5-6ecf-11d6-8ff8-00022d09712b  (2.0G)
      4194432  15623858696     2  516e7cba-6ecf-11d6-8ff8-00022d09712b  (7.3T)
root@vtxnas1:~ #
gpart list -a:
root@vtxnas1:~ # gpart list -a
Geom name: nvd0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 488397127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: nvd0p1
   Mediasize: 272629760 (260M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 20480
   Mode: r0w0e0
   efimedia: HD(1,GPT,fb775878-5cd1-11e8-abf9-ac1f6b17114e,0x28,0x82000)
   rawuuid: fb775878-5cd1-11e8-abf9-ac1f6b17114e
   rawtype: c12a7328-f81f-11d2-ba4b-00a0c93ec93b
   label: (null)
   length: 272629760
   offset: 20480
   type: efi
   index: 1
   end: 532519
   start: 40
2. Name: nvd0p2
   Mediasize: 249786675200 (233G)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 272650240
   Mode: r1w1e1
   efimedia: HD(2,GPT,fb7da104-5cd1-11e8-abf9-ac1f6b17114e,0x82028,0x1d143918)
   rawuuid: fb7da104-5cd1-11e8-abf9-ac1f6b17114e
   rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 249786675200
   offset: 272650240
   type: freebsd-zfs
   index: 2
   end: 488397119
   start: 532520
Consumers:
1. Name: nvd0
   Sectorsize: 512
   Mode: r1w1e2
Geom name: ada0
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 15628053127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada0p1
   Mediasize: 9663676416 (9.0G)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,189999a0-ac53-11ea-a0dd-ac1f6b17114e,0x80,0x1200000)
   rawuuid: 189999a0-ac53-11ea-a0dd-ac1f6b17114e
   rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 9663676416
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 18874495
   start: 128
2. Name: ada0p2
   Mediasize: 7991899459584 (7.3T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   efimedia: HD(2,GPT,18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e,0x1200080,0x3a2612a08)
   rawuuid: 18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e
   label: (null)
   length: 7991899459584
   offset: 9663741952
   type: freebsd-zfs
   index: 2
   end: 15628053127
   start: 18874496
Consumers:
1. Name: ada0
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
Geom name: ada1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 15628053127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada1p1
   Mediasize: 2147483648 (2.0G)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,140a8240-60d4-11e8-a658-ac1f6b17114e,0x80,0x400000)
   rawuuid: 140a8240-60d4-11e8-a658-ac1f6b17114e
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada1p2
   Mediasize: 7999415652352 (7.3T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   efimedia: HD(2,GPT,141a4ce3-60d4-11e8-a658-ac1f6b17114e,0x400080,0x3a3412a08)
   rawuuid: 141a4ce3-60d4-11e8-a658-ac1f6b17114e
   label: (null)
   length: 7999415652352
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 15628053127
   start: 4194432
Consumers:
1. Name: ada1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
Geom name: ada2
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 15628053127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,14bbb1d3-60d4-11e8-a658-ac1f6b17114e,0x80,0x400000)
   rawuuid: 14bbb1d3-60d4-11e8-a658-ac1f6b17114e
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada2p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   efimedia: HD(2,GPT,14cb9361-60d4-11e8-a658-ac1f6b17114e,0x400080,0x3a3412a08)
   rawuuid: 14cb9361-60d4-11e8-a658-ac1f6b17114e
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 15628053127
   start: 4194432
Consumers:
1. Name: ada2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
Geom name: ada3
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 15628053127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,15778508-60d4-11e8-a658-ac1f6b17114e,0x80,0x400000)
   rawuuid: 15778508-60d4-11e8-a658-ac1f6b17114e
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada3p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   efimedia: HD(2,GPT,157d13bd-60d4-11e8-a658-ac1f6b17114e,0x400080,0x3a3412a08)
   rawuuid: 157d13bd-60d4-11e8-a658-ac1f6b17114e
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 15628053127
   start: 4194432
Consumers:
1. Name: ada3
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
root@vtxnas1:~ #
sysctl kern.geom.conftxt:
root@vtxnas1:~ # sysctl kern.geom.conftxt
kern.geom.conftxt: 0 DISK ada4 10000831348736 512 hd 16 sc 63
0 DISK ada3 8001563222016 512 hd 16 sc 63
1 PART ada3p2 7999415652352 512 i 2 o 2147549184 ty freebsd-zfs xs GPT xt 516e7cba-6ecf-11d6-8ff8-00022d09712b
2 LABEL gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e 7999415652352 512 i 0 o 0
3 ELI gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e.eli 7999415648256 4096
1 PART ada3p1 2147483648 512 i 1 o 65536 ty freebsd-swap xs GPT xt 516e7cb5-6ecf-11d6-8ff8-00022d09712b
2 LABEL gptid/15778508-60d4-11e8-a658-ac1f6b17114e 2147483648 512 i 0 o 0
0 DISK ada2 8001563222016 512 hd 16 sc 63
1 PART ada2p2 7999415652352 512 i 2 o 2147549184 ty freebsd-zfs xs GPT xt 516e7cba-6ecf-11d6-8ff8-00022d09712b
2 LABEL gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e 7999415652352 512 i 0 o 0
3 ELI gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e.eli 7999415648256 4096
1 PART ada2p1 2147483648 512 i 1 o 65536 ty freebsd-swap xs GPT xt 516e7cb5-6ecf-11d6-8ff8-00022d09712b
2 LABEL gptid/14bbb1d3-60d4-11e8-a658-ac1f6b17114e 2147483648 512 i 0 o 0
0 DISK ada1 8001563222016 512 hd 16 sc 63
1 PART ada1p2 7999415652352 512 i 2 o 2147549184 ty freebsd-zfs xs GPT xt 516e7cba-6ecf-11d6-8ff8-00022d09712b
2 LABEL gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e 7999415652352 512 i 0 o 0
3 ELI gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e.eli 7999415648256 4096
1 PART ada1p1 2147483648 512 i 1 o 65536 ty freebsd-swap xs GPT xt 516e7cb5-6ecf-11d6-8ff8-00022d09712b
2 LABEL gptid/140a8240-60d4-11e8-a658-ac1f6b17114e 2147483648 512 i 0 o 0
0 DISK ada0 8001563222016 512 hd 16 sc 63
1 PART ada0p2 7991899459584 512 i 2 o 9663741952 ty freebsd-zfs xs GPT xt 516e7cba-6ecf-11d6-8ff8-00022d09712b
2 LABEL gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e 7991899459584 512 i 0 o 0
3 ELI gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e.eli 7991899455488 4096
1 PART ada0p1 9663676416 512 i 1 o 65536 ty freebsd-swap xs GPT xt 516e7cb5-6ecf-11d6-8ff8-00022d09712b
2 LABEL gptid/189999a0-ac53-11ea-a0dd-ac1f6b17114e 9663676416 512 i 0 o 0
0 DISK nvd0 250059350016 512 hd 0 sc 0
1 PART nvd0p2 249786675200 512 i 2 o 272650240 ty freebsd-zfs xs GPT xt 516e7cba-6ecf-11d6-8ff8-00022d09712b
1 PART nvd0p1 272629760 512 i 1 o 20480 ty efi xs GPT xt c12a7328-f81f-11d2-ba4b-00a0c93ec93b
2 LABEL gptid/fb775878-5cd1-11e8-abf9-ac1f6b17114e 272629760 512 i 0 o 0
glabel status:
root@vtxnas1:~ # glabel status
                                      Name  Status  Components
gptid/fb775878-5cd1-11e8-abf9-ac1f6b17114e     N/A  nvd0p1
gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e     N/A  ada0p2
gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e     N/A  ada1p2
gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e     N/A  ada2p2
gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e     N/A  ada3p2
gptid/15778508-60d4-11e8-a658-ac1f6b17114e     N/A  ada3p1
gptid/14bbb1d3-60d4-11e8-a658-ac1f6b17114e     N/A  ada2p1
gptid/140a8240-60d4-11e8-a658-ac1f6b17114e     N/A  ada1p1
gptid/189999a0-ac53-11ea-a0dd-ac1f6b17114e     N/A  ada0p1
root@vtxnas1:~ #
zpool status:
root@vtxnas1:~ # zpool status
  pool: freenas-boot
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
        still be used, but some features are unavailable.
        the features. See zpool-features(5) for details.
  scan: scrub repaired 0B in 00:00:06 with 0 errors on Sat Mar 20 03:45:06 2021
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
          nvd0p2      ONLINE       0     0     0
errors: No known data errors
zpool import:
root@vtxnas1:~ # zpool import
no pools available to import
sqlite3 /data/freenas-v1.db:
root@vtxnas1:~ # sqlite3 /data/freenas-v1.db
SQLite version 3.32.3 2020-06-18 14:00:33
Enter ".help" for usage hints.
sqlite> select * from storage_volume;
sqlite> select * from storage_encrypteddisk;
sqlite>
strings /data/zfs/zpool.cache | grep gptid:
root@vtxnas1:/dev/gptid # strings /data/zfs/zpool.cache | grep gptid
/dev/gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e.eli
/dev/gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e.eli
/dev/gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e.eli
/dev/gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e.eli
In the process of troubleshooting, I did a geli init -s 4096 <path to geli.key> gptid/<all files in /dev/gptid>
I don't know if that helped or not but I did save the corresponding *.eli files in /var/backups/.
It was at this point that was finally able to attach\decrypt some of the drives as listed in /dev/gptid.
So, I looked at the contents of tables storage_volume and storage_encrypteddisk in the /data/freenas-db.v1:
root@vtxnas1:/dev/gptid # sqlite3 /data/freenas-db.v1
sqlite> .mode column
sqlite> .header on
5|pool0|8048064432906907370|2|6a6eafbb-236a-470b-b27b-290c29342119
sqlite> .exit
and
root@vtxnas1:/dev/gptid # /usr/local/bin/sqlite3 /data/freenas-v1.db "select * from storage_encrypteddisk;"
2|5|{serial_lunid}ZA18VL80_5000c500a4683f57|gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e
3|5|{serial_lunid}ZA169QV9_5000c5007441b14a|gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e
4|5|{serial_lunid}R6GK648Y_5000cca263c7d159|gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e
5|5|{serial_lunid}ZA18TS5R_5000c500a467fd91|gptid/e62770de-f578-11e8-bc7a-ac1f6b17114e
NOTICE that the last row with id=5 is not a file that exists under /dev/gptid:
root@vtxnas1:/dev/gptid # ll
total 0
crw-r-----  1 root  operator  0xe1 Mar 23 21:14 140a8240-60d4-11e8-a658-ac1f6b17114e
crw-r-----  1 root  operator  0xbf Mar 23 21:09 141a4ce3-60d4-11e8-a658-ac1f6b17114e
crw-r-----  1 root  operator  0xc6 Mar 23 21:14 14bbb1d3-60d4-11e8-a658-ac1f6b17114e
crw-r-----  1 root  operator  0xc1 Mar 23 21:09 14cb9361-60d4-11e8-a658-ac1f6b17114e
crw-r-----  1 root  operator  0xb0 Mar 23 21:14 15778508-60d4-11e8-a658-ac1f6b17114e
crw-r-----  1 root  operator  0xc7 Mar 23 21:09 157d13bd-60d4-11e8-a658-ac1f6b17114e
crw-r-----  1 root  operator  0xc0 Mar 23 21:14 189999a0-ac53-11ea-a0dd-ac1f6b17114e
crw-r-----  1 root  operator  0xb1 Mar 23 21:09 18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e
crw-r-----  1 root  operator  0x6c Mar 23 21:09 fb775878-5cd1-11e8-abf9-ac1f6b17114e
So, I used DB Browser (SQLite) to open /data/freenas-v1.db and browse the storage_encrypteddisk table and replaced e62770de-f578-11e8-bc7a-ac1f6b17114e with 18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e.
Then, I attached them:
root@vtxnas1:/dev/gptid # geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e
Enter passphrase:
root@vtxnas1:/dev/gptid # geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e
Enter passphrase:
root@vtxnas1:/dev/gptid # geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e
Enter passphrase:
root@vtxnas1:/dev/gptid # geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e
Enter passphrase:
And I detach them using the following command so that I can try to import the pool using the GUI and let it decrypt the disks:
geli detach /dev/gptid/*.eli
Why did I choose just those four files, you may ask?
Because, when I used the GUI and tried to import an existing pool, it would successfully decrypt the above disks as shown below:
I WILL DECRYPT THE DISKS BUT I CANNOT SELECT A POOL:
Now, look at the contents of /dev/gptid:
total 0
crw-r-----  1 root  operator  0xe2 Mar 23 21:54 141a4ce3-60d4-11e8-a658-ac1f6b17114e.eli
crw-r-----  1 root  operator  0xe3 Mar 23 21:54 14cb9361-60d4-11e8-a658-ac1f6b17114e.eli
crw-r-----  1 root  operator  0xe4 Mar 23 21:54 157d13bd-60d4-11e8-a658-ac1f6b17114e.eli
crw-r-----  1 root  operator  0xbe Mar 23 21:53 18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e.eli
Now, I REALLY DO WONDER what the extra, non-*.eli disk\files are for???
Why do I say that they are extra? Keep reading, please.
Because when I use the GUI to attempt to import the pool, select the four disks, it attaches\decrypts only the ones with *.eli.
Here's where I am at now...
I am still able to attach\decrypt and detach the disks.
I still cannot import the pool, either by using the GUI or using zpool import and its various switches.
If I attach\decrypt only gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e.eli, I am able to use to use /data/zfs/zpool.cache to attempt a zpool import:
root@vtxnas1:~ # geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e
Enter passphrase:
root@vtxnas1:~ # zpool import -F -c /data/zfs/zpool.cache
   pool: pool0
  state: UNAVAIL
status: One or more devices are missing from the system.
 action: The pool cannot be imported. Attach the missing
        devices and try again.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-3C
        pool0                                               UNAVAIL  insufficient replicas
          raidz2-0                                          UNAVAIL  insufficient replicas
            gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e.eli  ONLINE
            gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e.eli  UNAVAIL  cannot open
            gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e.eli  UNAVAIL  cannot open
            gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e.eli  UNAVAIL  cannot open
root@vtxnas1:~ #
Otherwise, if I attach\decrypt all four disks and try to zpool import in the same way above, this is what I get:
root@vtxnas1:~ # geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e
Enter passphrase:
root@vtxnas1:~ # geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e
Enter passphrase:
root@vtxnas1:~ # geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e
Enter passphrase:
   pool: pool0
  state: FAULTED
status: One or more devices contains corrupted data.
 action: The pool cannot be imported due to damaged devices or data.
        The pool may be active on another system, but can be imported using
        the '-f' flag.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-5E
        pool0                                               FAULTED  corrupted data
          raidz2-0                                          ONLINE
            gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e.eli  UNAVAIL  corrupted data
            gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e.eli  UNAVAIL  corrupted data
            gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e.eli  UNAVAIL  corrupted data
            gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e.eli  UNAVAIL  corrupted data
root@vtxnas1:~ #
I'm not sure what the difference is by having "gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e.eli ONLINE"
Also, this ZFS-8000-5E really, really worries me. :frown:
So, I did some more research.
According to various articles, there are mentions of metadata, labels, ueberblocks, etc.
For example, in https://www.reddit.com/r/freebsd/comments/3nujw3/zfs_corruption_after_upgrade_from_101_to_102/ I did zdb -l </dev/ada0p2 .. /dev/ada3p2> and always got the following result, as an example:
root@vtxnas1:~ # zdb -l /dev/ada3p2
failed to unpack label 0
failed to unpack label 1
failed to unpack label 2
failed to unpack label 3
The above is the what I mentioned by "see the end".
I suppose I could try to use the "ZFS labelfix" but I think that's what zpool import -F does or is supposed to fix.
So, I don't know where I am at now.
I see those extra disks in /dev/gptid that don't seem to correlate with any of the physical disks.
What are they? Can I use them to recover and import the pool, somehow?
Can ANYONE PLEASE HELP!:eek:
Voltrix
HolyK
Ninja Turtle
Do you have backup of the config.db from before the upgrade (assuming all worked OK). If so check output of:
sqlite3 /path/to/cfgbackup.db
SELECT storage_volume.vol_name, storage_encrypteddisk.encrypted_provider from storage_volume JOIN storage_encrypteddisk ON storage_volume.id = storage_encrypteddisk.encrypted_volume_id;
It should give you details about which devices/IDs are expected.
Voltrix
I have an older backup from March 7, 2020 but not one from immediately before the upgrade.
Here is the output of that query:
sqlite> SELECT storage_volume.vol_name, storage_encrypteddisk.encrypted_provider from storage_volume JOIN storage_encrypteddisk ON storage_volume.id = storage_encrypteddisk.encrypted_volume_id;
pool0|gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e
pool0|gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e
pool0|gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e
pool0|gptid/e62770de-f578-11e8-bc7a-ac1f6b17114e
sqlite>
HolyK
Ninja Turtle
You've mentioned that but still i need to ask ... what happened to that one disk? Any replacements over the year?
Old: gptid/e62770de-f578-11e8-bc7a-ac1f6b17114e
New: gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e
//EDIT: Can you get these from the backup DB file...
select * from storage_disk;
select * from storage_mountpoint;
Voltrix
That one disk was resilvered at least a couple of times because it went offline. But I haven't had any issues with it in the last 6 months.
I did not replace that disk (ada0).
No, I haven't replaced any disks over the year. I did add a new HDD but it currently sits empty, unattached and this new HDD has never been used.
That new HDD (ada4) was never used in the damaged pool.
Output of the commands:
root@vtxnas1:~ # sqlite3 ./vtxnas1-20200307201000.db
sqlite> select * from storage_disk;
{serial_lunid}R6GK648Y_5000cca263c7d159|ada3|ada|3|R6GK648Y|8001563222016||||Auto|Always On|Disabled|Disabled|1||||||||WDC WD80PURZ-85YNPY0|5400|HDD
{serial_lunid}ZA169QV9_5000c5007441b14a|ada2|ada|2|ZA169QV9|8001563222016||||Auto|Always On|Disabled|Disabled|1||||||||ST8000VN0022-2EL112|7200|HDD
{serial_lunid}ZA18VL80_5000c500a4683f57|ada1|ada|1|ZA18VL80|8001563222016||||Auto|Always On|Disabled|Disabled|1||||||||ST8000VN0022-2EL112|7200|HDD
{serial_lunid}ZA18TS5R_5000c500a467fd91|ada0|ada|0|ZA18TS5R|8001563222016||||Auto|Always On|Disabled|Disabled|1||||||||ST8000VN0022-2EL112|7200|HDD
{serial}S3ESNX1K302721Z|nvd0|nvd|0|S3ESNX1K302721Z|250059350016||||Auto|Always On|Disabled|Disabled|1||||||||Samsung SSD 960 EVO 250GB||SSD
|ada0|ada|0||||||Auto|Always On|Disabled|Disabled|1||2020-02-23 08:22:08.639778||||||||UNKNOWN
sqlite> select * from storage_mountpoint;
sqlite>
Note that select * from storage_mountpoint; did not return anything.
Thank you for your interest thus far.
HolyK
Ninja Turtle
I see it is a Z2, can you try attach only two out of four in read-only (-r) and try to import it (in a degraded state but still). Also use the /dev/adaXp2 instead of the glabel (we have the mapping from before so we know which one is which)
geli attach -r -k /data/geli/correct_key_name.key /dev/ada2p2 geli attach -r -k /data/geli/correct_key_name.key /dev/ada3p2 zpool import zpool import pool0
Voltrix
I executed the commands and here's the output:
root@vtxnas1:/dev # geli attach -r -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/ada2p2
Enter passphrase:
root@vtxnas1:/dev # geli attach -r -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/ada3p2
Enter passphrase:
root@vtxnas1:/dev # zpool import
root@vtxnas1:/dev # zpool import pool0
cannot import 'pool0': no such pool available
root@vtxnas1:/dev # ll *.eli
crw-r-----  1 root  operator  0xb5 Mar 25 16:05 ada2p2.eli
crw-r-----  1 root  operator  0xc3 Mar 25 16:06 ada3p2.eli
root@vtxnas1:/dev #
The pool0 is not "visible".
//EDIT
I went a little further and attached the first three only (i.e.: excluded ada3p2) and got the same result:
root@vtxnas1:/dev # geli detach /dev/*.eli
root@vtxnas1:/dev # geli attach -r -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/ada0p2
Enter passphrase:
root@vtxnas1:/dev # geli attach -r -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key /dev/ada1p2
Enter passphrase:
Enter passphrase:
crw-r-----  1 root  operator  0xb5 Mar 25 16:08 ada0p2.eli
crw-r-----  1 root  operator  0xc3 Mar 25 16:09 ada1p2.eli
crw-r-----  1 root  operator  0xc5 Mar 25 16:09 ada2p2.eli
root@vtxnas1:/dev #
HolyK
Ninja Turtle
Uhm, i don't expect you have backup of the GPT and the Geli metadata from before it got broken?
Also after you decrypt the disks from shell check dmesg and messages.
Voltrix
@HolyK, no, I do not have a backup of the GPT and the GELI metadata.
To be precise, I do not know where the backup of the GPT would be, though.
I believe that the backup of GELI metadata would have been in /var/backups but that directory was empty.
To expand on that further, in my original post, I did do geli init -s 4096 <path to geli.key> gptid/<all files in /dev/gptid>.
BUT
, that was done after the problem occurred.
I did keep a backup of the .eli metadata files when I did the geli init ... and since then I have done geli restore /var/backups/<GPT ID>.eli gptid/<GPT ID> to see if that changes the outcome (if I'm able to zpool import).
e.g.: geli restore /var/backups/gptid_140a8240-60d4-11e8-a658-ac1f6b17114e.eli gptid/140a8240-60d4-11e8-a658-ac1f6b17114e
After this restore I am still able to do geli attach -r -k <etc> but zpool import still returns with "no pools available to import"
Here's what I get in /var/log/messages when I geli attach -r -k <etc>:
Mar 31 17:23:27 vtxnas1 GEOM_ELI: Device ada0p2.eli created.
Mar 31 17:23:27 vtxnas1 GEOM_ELI: Encryption: AES-XTS 128
Mar 31 17:23:27 vtxnas1 GEOM_ELI:     Crypto: hardware
Mar 31 17:23:29 vtxnas1 GEOM_ELI: Device ada1p2.eli created.
Mar 31 17:23:29 vtxnas1 GEOM_ELI: Encryption: AES-XTS 128
Mar 31 17:23:29 vtxnas1 GEOM_ELI:     Crypto: hardware
Mar 31 17:23:30 vtxnas1 GEOM_ELI: Device ada2p2.eli created.
Mar 31 17:23:30 vtxnas1 GEOM_ELI: Encryption: AES-XTS 128
Mar 31 17:23:30 vtxnas1 GEOM_ELI:     Crypto: hardware
Mar 31 17:23:32 vtxnas1 GEOM_ELI: Device ada3p2.eli created.
Mar 31 17:23:32 vtxnas1 GEOM_ELI: Encryption: AES-XTS 128
Mar 31 17:23:32 vtxnas1 GEOM_ELI:     Crypto: hardware
Similarly, the end of dmesg shows:
HolyK
Ninja Turtle
Ok after all the fiddling if you unlock all four disks and then do zpool import do you still get Faulted state with "UNAVAIL corrupted data" like before? Or that does not work anymore?
Samuel Tai
First, try rebooting back into 11.3-U5 by setting it as the boot environment to use as the next boot. If your pool is available there, I would recommend staying on 11.3-U5.
Voltrix
@HolyK I get the error "UNAVAIL corrupted data" if, and only if, I do zpool import -c /data/zfs/zpool.cache as shown below:
root@vtxnas1:~ # zpool import -c /data/zfs/zpool.cache
   pool: pool0
  state: UNAVAIL
            gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e.eli  UNAVAIL  cannot open
root@vtxnas1:~ #
HolyK
Ninja Turtle
That one says "cannot open" ... Seems like disks are not decrypted...
@Samuel Tai In OP he states he upgraded the pool so there is no way back to 11.3 anymore... And also he alrrady tried to roll back to 11.3 but faced the same import issues.
Voltrix
@Samuel Tai, I appreciate your suggestion. Like @HolyK said, I have tried that with no success.
Ultimately, "something" doesn't seem to know of "pool0" with vol_guid 8048064432906907370.
That is to say, I am able to decrypt\attach the disk, either through though GUI (until it errors with "[ENOENT] Pool 8048064432906907370 not found.") or if I use geli attach -r -k <etc> or geli attach -k <etc>.
And I've attached\decrypted the disks in two ways:
geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key -j ~/pool0_encryption.pw /dev/ada0p2
geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key -j ~/pool0_encryption.pw /dev/ada1p2
geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key -j ~/pool0_encryption.pw /dev/ada2p2
geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key -j ~/pool0_encryption.pw /dev/ada3p2
geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key -j ~/pool0_encryption.pw /dev/gptid/18b9c2bc-ac53-11ea-a0dd-ac1f6b17114e
geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key -j ~/pool0_encryption.pw /dev/gptid/141a4ce3-60d4-11e8-a658-ac1f6b17114e
geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key -j ~/pool0_encryption.pw /dev/gptid/14cb9361-60d4-11e8-a658-ac1f6b17114e
geli attach -k /data/geli/6a6eafbb-236a-470b-b27b-290c29342119.key -j ~/pool0_encryption.pw /dev/gptid/157d13bd-60d4-11e8-a658-ac1f6b17114e
Either way, the pool "pool0" just doesn't seem to exist.
Samuel Tai
I'm afraid you're out of luck, and your only option is to rebuild your pool. I suspect your pool has different ZFS options outside and within the GELI-encryption, which is not a supported configuration. I suspected this might happen on upgrade to 12, so I used @Patrick M. Hausen's procedure to convert my GELI-encrypted pool to an unencrypted pool before upgrade. After upgrade, I'm planning to destroy and recreate my pool using native ZFS encryption once I have enough replicas available for restore.
HolyK
Ninja Turtle
Enter passphrase:
Enter passphrase:
Enter passphrase:
   pool: pool0
  state: FAULTED
        the '-f' flag.
          raidz2-0                                          ONLINE
root@vtxnas1:~ #
Can you replicate this state? (So it says corrupted data, not unavail). If you do try to import with flags -Fn.
Voltrix
Running the command zpool import -Fn -c /data/zfs/zpool.cache gives me the same result:
root@vtxnas1:~ # zpool import -Fn -c /data/zfs/zpool.cache
   pool: pool0
  state: FAULTED
        the '-f' flag.
          raidz2-0                                          ONLINE
root@vtxnas1:~ #
HolyK
Ninja Turtle
Sorry for late reply, busy days ... anyway i am out of ideas in this case :/ . Apparently the GPT/metadata got corrupted. Next step would be to start messing with it manually but that is a "Here be dragons" place.
I would suggest to try to reach out @rfang9524 @theyost @icyy as these ppl did some of the manual revive of "broken" encrypted pools.
csj
I'm unsure if geli init on a disk that already has been initialized with geli wipes the existing metadata which means you could have potentially caused the corruption by simply running that command. :frown:
Anyways, we keep a backup of the geli key that is used to initialize the disks in /data/geli/. If you have that key you can try the following.
If you originally setup the zpool with a passphrase then run this:
geli attach -j <your-passphrase> -k /data/geli/<the-key> /dev/gptid/<the-guid-for-the-disk>.eli
If you didn't setup the zpool with a passphrase then run:
geli attach -p -k /data/geli/<your-key> /dev/gpid/<the-guid-for-the-disk>.eli
