rfang9524
- Jan 3, 2019
The issue I had was the encryption on my new drives did not finish prior to a shutdown. I was able to use the recovery key to decrypt the existing drives and use the encryption key to decrypt the new drives that didn't finish encrypting. See https://www.truenas.com/community/t...rtitions-gone-on-all-drives.82261/post-635413
Also, I just ran "zpool import -a" after all of the drives are decrypted and "attach".
- What does it show when you run "geli status" after you use "geli attach..." all of the drives? Are they showing up as "ACTIVE"? I didn't need to specify the encryption passphrase in the command. It's either the recovery key or the encryption key.
- Are you able to "geli attach" all of the drives? I couldn't tell since some of the commands you posted only had three drives "attach".
