Aron Dijkstra
- Apr 24, 2014
I just switched to FreeNAS in the hopes it has advantages above stock FreeBSD.
Now i copied all the data from servers to other servers so i can make the switch.
All went fine. The only problem was that the disk would not spin down (But ok i can live with that)
The speed increase of freenas is great!
Now my problem. I was moving the data arround so i had the proper new directory structure i really wanted. After copying all my pictures (about 10.000 to 30.000) the system dit not respond anymore.
I tried logging into SSH. it worked. i can change directorys all ok. But when i get to the Picture diretory i cannot ls it. if i go to one directory above i can make a ls but no ls -al...
I tried a Find . -type f also no success. I waited for 10 minutes no response. if i look in top the sh command is in wait.
Now i enabled smart. it says disk 3 (ada3) is offline... but zpool status all disks online????
I started a scrub. i hope it helps.
I hope. I really really hope someone can help and give a solution so i can get my life back.
And if u ask. backup. well i just got fnished moving all the data arround and needed to use my backup disk for a temp storage....
Hope there is a good awser that does not include u lost everything.
With regards!
Aron
With regards!
Aron
