RAIDZ2 after disk replacment all disk degraded (need Help!)
I sent you a private message with some more locally specific suggestions about what to get.
Not to put you down but the side to figure out my controller does not help. That is for a Linux system and not freebsd.
I wasn't actually intending for you to look at that link as the instructions for what to do, just an example of the syntax you need to find (actually I really only looked at this first bit... smartctl -a -d sat+megaraid,3 /dev/sda... for what you would need to figure out for your card in particular, obviously in TrueNAS/FreeBSD as that's what you're using.
MutoSan
For most disks its this:
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N0XHC2SJ
LU WWN Device Id: 5 0014ee 2b8f5cc67
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Oct 28 14:13:42 2021 CEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (40500) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 406) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 403
3 Spin_Up_Time 0x0027 179 175 021 Pre-fail Always - 6033
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 23
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 056 056 000 Old_age Always - 32178
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 23
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 13
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 3526
194 Temperature_Celsius 0x0022 117 101 000 Old_age Always - 33
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
I think ada3-8 are on board and and 1-2 are on the Sata Controller. There is one or two disks where it looks like this:
Serial Number: WD-WCC4N3SRHKN6
LU WWN Device Id: 5 0014ee 2b963eeb8
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Thu Oct 28 14:15:43 2021 CEST
was never started.
been run.
data collection: (41040) seconds.
command.
power-saving mode.
recommended polling time: ( 412) minutes.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 182 178 021 Pre-fail Always - 5900
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 35
9 Power_On_Hours 0x0032 056 056 000 Old_age Always - 32207
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 35
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 20
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 3592
194 Temperature_Celsius 0x0022 118 102 000 Old_age Always - 32
No Errors Logged
# 1 Short offline Completed without error 00% 19200 -
# 2 Short offline Completed without error 00% 19030 -
# 3 Short offline Completed without error 00% 18863 -
# 4 Short offline Completed without error 00% 18695 -
# 5 Short offline Completed without error 00% 18527 -
# 6 Short offline Completed without error 00% 18359 -
# 7 Short offline Completed without error 00% 18192 -
# 8 Short offline Completed without error 00% 18024 -
# 9 Short offline Completed without error 00% 17857 -
#10 Short offline Completed without error 00% 17689 -
#11 Short offline Completed without error 00% 17521 -
#12 Short offline Completed without error 00% 17353 -
#13 Short offline Completed without error 00% 17185 -
#14 Short offline Completed without error 00% 17017 -
#15 Short offline Completed without error 00% 16850 -
#16 Short offline Completed without error 00% 16682 -
#17 Short offline Completed without error 00% 16514 -
#18 Short offline Completed without error 00% 16346 -
#19 Short offline Completed without error 00% 16178 -
#20 Short offline Completed without error 00% 16010 -
#21 Short offline Completed without error 00% 15843 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
OK, so for whichever that first disk is, you have a problem:
That's 403 read errors reported by the disk itself.
The second one is clean
It could be that, but are you sure that's the one from that report?
Seeing just that block of data for each of the disks in code tags would be really helpful... like this:
ada1
jgreco
Resident Grinch
@Etorix, you are the reason why I stopped using community boards. Instead of helping you just criticize, judge, lecture and challenge things.
Moderator note: Please consider that community members are not paid support staff, and are graciously taking time out of their own lives to try to help others. I strongly suggest considering the forum equivalent of Postel's law, which is to be liberal in what you accept and conservative in what you write. If you want to run around trying to find reasons to be offended by everything, that's easy to do, but it only hurts YOU in the end. The people here have all sorts of personalities, but in my experience they will try to set you on the right path going forward.
We criticize design decisions we see that are known to be a problem. Use of random RAID controllers is a known problem. My criticism of this is a large post all by itself.
We judge situations by their own merits. Using a RAID controller, for example, works fine, until it doesn't. This can sometimes be recoverable, but sometimes not. Either way, I judge it tragic.
We lecture people on how to do things right, not because we like to lecture, but because we want to see your NAS be a safe and successful place to store data. Years of experience indicates that there are MANY ways for thing to go wrong, and only a small set of ways to do it correctly.
We challenge things because it often turns out that the "devil is in the details," as they say. Challenging things is often the way we discover the root causes of user issues.
If you can knock the chip off your shoulder and and try to work with folks, you are much more likely to have a successful resolution, and you'll undoubtedly also get a lot of information on how you can improve your setup for the future. Criticizing, lecturing, judging, and challenging is part of the process of helping. Don't take it as some sort of personal affront.
MutoSan
ada1
no its a different serial nummber. Just checked. So there is another disk failing. Thats bad. I ordered 2 new 4TB disks they just literately arrived.
MutoSan
Still is not the way to ask for such things. As you can see it can be misunderstood pretty fast. And he did not lecture me about how todo things better he lecture me about oh this is wrong and that is wrong and that is also wrong. Which at the end does not solve the problem and does not help anyone.
And the challange was on my signature which has nothing todo with what I asked for. And a moderator which does not see that should not be a moderator.
First fix a problem then go for things that have to be changed. This is the professional way and I can speak out of over 10 years of IT support experience. Never ever have we said to customers first ah that has to be changed this needs to be changed and thats totaly wrong. First you fix a problem and then you tell the customer what was wrong what needs to be done and what has to change.
just a thought. If I put in the new LSI SAS controller do you think the resilvering will work better? As the resilvering is now up 1day and 2hrs. Or should I just wait 2-3 days until its finished?
If we're able to get smartctl data from all disks I think that's the first priority as resilvering is only going to help if we don't have any bad disks in the mix.
Make very sure that any new disks aren't EFAX models.
MutoSan
So then the problem is at least with ada7 and ada8
root@freenas[/]# smartctl -a /dev/ada8
Device Model: WDC WD30EFRX-68N32N0
Serial Number: WD-WCC7K1KCA16V
LU WWN Device Id: 5 0014ee 2b9d867bd
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Thu Oct 28 14:46:18 2021 CEST
was never started.
been run.
data collection: (32640) seconds.
command.
power-saving mode.
recommended polling time: ( 347) minutes.
SCT capabilities: (0x303d) SCT Status supported.
3 Spin_Up_Time 0x0027 194 168 021 Pre-fail Always - 5258
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 20
9 Power_On_Hours 0x0032 079 079 000 Old_age Always - 15466
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 20
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 15
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 515
194 Temperature_Celsius 0x0022 119 102 000 Old_age Always - 31
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Still need to find out how I can read the ones on the Sata Adapter on PCI-E
maybe have a look at this:
smartctl --scan
MutoSan
smartctl --scan
Thats the outcome:
root@freenas[/]# smartctl --scan
/dev/pass3 -d atacam # /dev/pass3, ATA device
/dev/ada3 -d atacam # /dev/ada3, ATA device
/dev/ada4 -d atacam # /dev/ada4, ATA device
/dev/ada5 -d atacam # /dev/ada5, ATA device
/dev/ada6 -d atacam # /dev/ada6, ATA device
/dev/ada7 -d atacam # /dev/ada7, ATA device
/dev/ada8 -d atacam # /dev/ada8, ATA device
/dev/ses0 -d atacam # /dev/ses0, ATA device
I think /dev/pass3 is the passthrough from the sata controller?
I think you can ignore the first and last entries.
Can you get smartctl data from all the others (ada3-ada8) using the commands as suggested there?
like:
smartctl -a -d atacam /dev/ada3
I did already ada7 and ada8 but ill do all again
If we can see them all laid out clearly, we should be able to get a good picture of what's really wrong.
