SOLVED Help, Can't access my files
Chazore
Neophyte
I've had my freenas server for over a month so far and I have found it incredibly useful. However today it disappeared from the network section of windows fie explorer. My server is running freenas 9.10.2 and my desktop is running windows 10. I made no changes to any freenas settings before this problem arose. the webgui still works and it tells me the share still works and alll my drives are healthy
So far, to try and fix the problem, I have;
-tried accessing the files from my laptop, also running windows 10
-restart both my server and pc multiple times
-fully shut down both pcs, unplugged and plugged them both back in
-restarted my router and gigabit switch, both separately and together
-tried accessing the files from another windows 10 pc
-change dataset permissions to the recommended settings from 3 different guides and from the wiki
-changed my share settings to the recommended settings from those same 3 guides and of course the wiki
-created a new share point from scratch using the settings found on the wiki
-turned smb off and back on again
-replaced ethernet cables
-checked for errors using my server's ilo port
-pinged the server with windows to see if it was still responding(it was)
-created an nfs file share to see if windows would recognize that(it didn't)
-turned 48 and 56 file transfer encryption in windows sharing center
-turned off the requirement for passwords in order to access remote computers in windows sharing center
I have many important files including school assignments and irreplaceable family photos, and I would like to have them back asap. if anyone has any suggestion for something that may help.
m0nkey_
Dedicated Sage
Is the SMB service running? If you're not sure, try stopping/starting it.
anodos
Sambassador
Post output of following commands (type them in the freenas CLI)
zpool status
zfs list
testparm
Enclose the output in [ code ] tags to properly format it.
Chazore
Neophyte
yes the smb service is running, I did try restating it, but it didn't help
Chazore
Neophyte
I tried the command the codes you suggested and here's the output;
zpool status
  pool: Library
state: ONLINE
  scan: none requested
		NAME										  STATE	 READ WRITE CKSUM
		Library									   ONLINE	   0	 0	 0
		  gptid/9eccf111-cba3-11e6-b4ad-78acc088e770  ONLINE	   0	 0	 0
		  gptid/9f9ad150-cba3-11e6-b4ad-78acc088e770  ONLINE	   0	 0	 0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0h0m with 0 errors on Thu Jan  2 03:45:43 2070
		freenas-boot  ONLINE	   0	 0	 0
		  da0p2	 ONLINE	   0	 0	 0
zfs list
Library/.system/syslog-eab18b758b91471d95803a91d80bfcda	872K  1.69T   872K  l
egacy
Library/Library										   65.6G  1.69T  65.6G  /
mnt/Library/Library
Library/jails											   23K  1.69T	23K  /
mnt/Library/jails
freenas-boot											   651M  28.2G	64K  n
one
freenas-boot/ROOT										  642M  28.2G	29K  n
one
freenas-boot/ROOT/Initial-Install							1K  28.2G   635M  l
egacy
freenas-boot/ROOT/Wizard-2016-12-26_13:59:46				 1K  28.2G   636M  l
egacy
freenas-boot/ROOT/Wizard-2016-12-26_15:17:30				 1K  28.2G   636M  l
egacy
freenas-boot/ROOT/Wizard-2070-01-02_22:28:52				 1K  28.2G   637M  l
egacy
freenas-boot/ROOT/default								  642M  28.2G   637M  l
egacy
freenas-boot/grub										 6.35M  28.2G  6.35M  l
egacy
ell
		server role = standalone server
		username map = /usr/local/etc/smbusers
		deadtime = 15
		hostname lookups = Yes
		max open files = 942554
		dns proxy = No
		idmap config * : backend = tdb
		store dos attributes = Yes
		strict locking = No
		directory name cache size = 0
		dos filemode = Yes
		acl allow execute always = Yes
		ea support = Yes
		create mask = 0666
		directory mask = 0777
[Library]
		path = /mnt/Library
		veto files = /.snapshot/.windows/.mac/.zfs/
		guest ok = Yes
		read only = No
		vfs objects = zfs_space zfsacl aio_pthread
		zfsacl:acesort = dontcare
		nfs4:chown = true
		nfs4:acedup = merge
		nfs4:mode = special
[root@Cap ~]# ^C
[root@Cap ~]# zfs list
NAME													   USED  AVAIL  REFER  MOUNTPOINT
Library												   65.7G  1.69T	31K  /mnt/Library
Library/.system										   2.09M  1.69T	25K  legacy
Library/.system/configs-eab18b758b91471d95803a91d80bfcda   383K  1.69T   383K  legacy
Library/.system/cores									  732K  1.69T   732K  legacy
Library/.system/rrd-eab18b758b91471d95803a91d80bfcda		23K  1.69T	23K  legacy
Library/.system/samba4									  99K  1.69T	99K  legacy
Library/.system/syslog-eab18b758b91471d95803a91d80bfcda	874K  1.69T   874K  legacy
Library/Library										   65.6G  1.69T  65.6G  /mnt/Library/Library
Library/jails											   23K  1.69T	23K  /mnt/Library/jails
freenas-boot											   651M  28.2G	64K  none
freenas-boot/ROOT										  642M  28.2G	29K  none
freenas-boot/ROOT/Initial-Install							1K  28.2G   635M  legacy
freenas-boot/ROOT/Wizard-2016-12-26_13:59:46				 1K  28.2G   636M  legacy
freenas-boot/ROOT/Wizard-2016-12-26_15:17:30				 1K  28.2G   636M  legacy
freenas-boot/ROOT/Wizard-2070-01-02_22:28:52				 1K  28.2G   637M  legacy
freenas-boot/ROOT/default								  642M  28.2G   637M  legacy
freenas-boot/grub										 6.35M  28.2G  6.35M  legacy
test parm
# Global parameters
[global]
		dos charset = CP437
		lm announce = Yes
		logging = file
		max log size = 51200
		kernel change notify = No
		pid directory = /var/run/samba
		disable spoolss = Yes
		load printers = No
		printcap name = /dev/null
		server min protocol = CORE
		time server = Yes
		guest account = root
		map to guest = Bad User
		obey pam restrictions = Yes
		security = USER
		deadtime = 15
		dns proxy = No
		strict locking = No
		dos filemode = Yes
		ea support = Yes
		create mask = 0666
[Library]
		path = /mnt/Library
		guest ok = Yes
		read only = No
		nfs4:chown = true
		nfs4:acedup = merge
		nfs4:mode =
Chazore
Neophyte
ok, so I just turned the server on and everything is working as it did before. I didn't do anything at all.
