ajschot
 - Nov 7, 2016
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Green Device Model: WDC WD40EZRX-00SPEB0 Serial Number: WD-WCC4E1174874 LU WWN Device Id: 5 0014ee 209dda498 Firmware Version: 80.00A80 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Oct 14 12:42:29 2018 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (54000) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 540) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x7035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 175 171 021 Pre-fail Always - 8216 4 Start_Stop_Count 0x0032 080 080 000 Old_age Always - 20824 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 069 069 000 Old_age Always - 23072 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 728 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 242 193 Load_Cycle_Count 0x0032 189 189 000 Old_age Always - 33988 194 Temperature_Celsius 0x0022 115 099 000 Old_age Always - 37 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 3 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 ATA Error Count: 10 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 10 occurred at disk power-on lifetime: 988 hours (41 days + 4 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 51 01 00 00 00 a0 Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- b0 d6 01 e0 4f c2 a0 00 00:01:42.872 SMART WRITE LOG b0 d6 01 e0 4f c2 a0 00 00:01:42.858 SMART WRITE LOG 80 45 01 01 44 57 a0 00 00:01:42.848 [VENDOR SPECIFIC] ec 44 01 01 00 00 a0 00 00:01:42.797 IDENTIFY DEVICE 80 44 10 00 44 57 a0 00 00:01:24.545 [VENDOR SPECIFIC] Error 9 occurred at disk power-on lifetime: 988 hours (41 days + 4 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 51 01 00 00 00 a0 Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- b0 d6 01 e0 4f c2 a0 00 00:01:42.858 SMART WRITE LOG 80 45 01 01 44 57 a0 00 00:01:42.848 [VENDOR SPECIFIC] ec 44 01 01 00 00 a0 00 00:01:42.797 IDENTIFY DEVICE 80 44 10 00 44 57 a0 00 00:01:24.545 [VENDOR SPECIFIC] b0 d6 01 e0 4f c2 a0 00 00:01:24.541 SMART WRITE LOG Error 8 occurred at disk power-on lifetime: 988 hours (41 days + 4 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 51 01 00 00 00 a0 Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- b0 d6 01 e0 4f c2 a0 00 00:01:24.541 SMART WRITE LOG b0 d6 01 e0 4f c2 a0 00 00:01:24.527 SMART WRITE LOG b0 d6 01 e0 4f c2 a0 00 00:01:24.510 SMART WRITE LOG b0 d6 01 e0 4f c2 a0 00 00:01:24.500 SMART WRITE LOG 80 45 01 01 44 57 a0 00 00:01:24.497 [VENDOR SPECIFIC] Error 7 occurred at disk power-on lifetime: 988 hours (41 days + 4 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 51 01 00 00 00 a0 Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- b0 d6 01 e0 4f c2 a0 00 00:01:24.527 SMART WRITE LOG b0 d6 01 e0 4f c2 a0 00 00:01:24.510 SMART WRITE LOG b0 d6 01 e0 4f c2 a0 00 00:01:24.500 SMART WRITE LOG 80 45 01 01 44 57 a0 00 00:01:24.497 [VENDOR SPECIFIC] ec 44 01 01 00 00 a0 00 00:01:24.446 IDENTIFY DEVICE Error 6 occurred at disk power-on lifetime: 988 hours (41 days + 4 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 51 01 00 00 00 a0 Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- b0 d6 01 e0 4f c2 a0 00 00:01:24.510 SMART WRITE LOG b0 d6 01 e0 4f c2 a0 00 00:01:24.500 SMART WRITE LOG 80 45 01 01 44 57 a0 00 00:01:24.497 [VENDOR SPECIFIC] ec 44 01 01 00 00 a0 00 00:01:24.446 IDENTIFY DEVICE 80 44 10 00 44 57 a0 00 00:00:52.074 [VENDOR SPECIFIC] SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 22813 - # 2 Short offline Completed without error 00% 22587 - # 3 Short offline Completed without error 00% 22331 - # 4 Short offline Completed without error 00% 22012 - # 5 Short offline Completed without error 00% 21820 - # 6 Short offline Completed without error 00% 21378 - # 7 Short offline Completed without error 00% 21237 - # 8 Short offline Completed without error 00% 21069 - # 9 Short offline Completed without error 00% 20984 - #10 Short offline Completed without error 00% 20816 - #11 Short offline Completed without error 00% 20648 - #12 Short offline Completed without error 00% 20545 - #13 Short offline Completed without error 00% 20410 - #14 Short offline Completed without error 00% 20254 - #15 Short offline Completed without error 00% 19994 - #16 Short offline Completed without error 00% 19832 - #17 Short offline Completed without error 00% 19664 - #18 Short offline Completed without error 00% 19504 - #19 Short offline Completed without error 00% 19336 - #20 Short offline Completed without error 00% 19168 - #21 Short offline Completed without error 00% 19000 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. root@freenas:~ #
I found a lot topics about "The status of volume Data is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected."
But, i tried to find which disk is giving errors, also the volume is not degraded, the repot above is the drive that only gives me some errors. The thing is, i think it is not that bad right? it was an idle error i think?
I really don't undestand the error is there somebody so kind to tell me what is wrong? And is there a way to reset this error to see if it will come back or not?
This error came after i had changed the power settings of the drives.
