Critical Drive Errors
ggoosen
  • CRITICAL: Sept. 6, 2017, 9:18 p.m. - Device: /dev/ada0, 12584 Currently unreadable (pending) sectors
  • CRITICAL: Sept. 6, 2017, 9:18 p.m. - Device: /dev/ada0, 12584 Offline uncorrectable sectors
  • CRITICAL: Sept. 6, 2017, 9:19 p.m. - The volume Disk12TB state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
I ran a smartctl -t short -C /dev/ada0
Below are the results.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Seagate Barracuda 7200.14 (AF)
Device Model:	 ST2000DM001-9YN164
Serial Number:	W1E07H33
LU WWN Device Id: 5 000c50 0454f83f1
Firmware Version: CC9D
User Capacity:	2,000,398,934,016 bytes [2.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	7200 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 1.5 Gb/s)
Local Time is:	Wed Sep  6 21:33:12 2017 ACST
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
Self-test execution status:	  ( 121)	The previous self-test completed having
					the read element of the test failed.
data collection:		 (  592) seconds.
capabilities:			 (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:			(0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:		(0x01)	Error logging supported.
Short self-test routine
recommended polling time:	 (   1) minutes.
Extended self-test routine
recommended polling time:	 ( 244) minutes.
Conveyance self-test routine
recommended polling time:	 (   2) minutes.
SCT capabilities:		   (0x3081)	SCT Status supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000f   090   090   006	Pre-fail  Always	   -	   66762136
  3 Spin_Up_Time			0x0003   095   094   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   156
  5 Reallocated_Sector_Ct   0x0033   100   100   036	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   078   060   030	Pre-fail  Always	   -	   8735073364
  9 Power_On_Hours		  0x0032   083   082   000	Old_age   Always	   -	   14944
10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   125
183 Runtime_Bad_Block	   0x0032   093   093   000	Old_age   Always	   -	   7
184 End-to-End_Error		0x0032   100   100   099	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   001   001   000	Old_age   Always	   -	   248
188 Command_Timeout		 0x0032   100   099   000	Old_age   Always	   -	   9 9 9
189 High_Fly_Writes		 0x003a   098   098   000	Old_age   Always	   -	   2
190 Airflow_Temperature_Cel 0x0022   082   039   045	Old_age   Always   In_the_past 18 (0 94 18 17 0)
191 G-Sense_Error_Rate	  0x0032   100   100   000	Old_age   Always	   -	   0
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   91
193 Load_Cycle_Count		0x0032   033   033   000	Old_age   Always	   -	   134125
194 Temperature_Celsius	 0x0022   018   061   000	Old_age   Always	   -	   18 (0 11 0 0 0)
197 Current_Pending_Sector  0x0012   063   017   000	Old_age   Always	   -	   6184
198 Offline_Uncorrectable   0x0010   063   017   000	Old_age   Offline	  -	   6184
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   0
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   2927h+51m+00.851s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   1450126304226
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   838585338767
SMART Error Log Version: 1
ATA Error Count: 226 (device log contains only the most recent five errors)
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Error 226 occurred at disk power-on lifetime: 14944 hours (622 days + 16 hours)
  ER ST SC SN CL CH DH
  40 51 00 20 d5 b4 05  Error: UNC at LBA = 0x05b4d520 = 95737120
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  c8 00 28 20 d5 b4 e5 00	  00:30:50.532  READ DMA
  c8 00 28 20 d5 b4 e5 00	  00:30:47.125  READ DMA
  b0 d5 01 06 4f c2 e0 00	  00:30:47.021  SMART READ LOG
  c8 00 28 20 d5 b4 e5 00	  00:30:43.593  READ DMA
  b0 d5 01 00 4f c2 e0 00	  00:30:43.524  SMART READ LOG
Error 225 occurred at disk power-on lifetime: 14944 hours (622 days + 16 hours)
  c8 00 28 20 d5 b4 e5 00	  00:30:40.100  READ DMA
Error 224 occurred at disk power-on lifetime: 14944 hours (622 days + 16 hours)
  b0 d0 01 00 4f c2 e0 00	  00:30:39.445  SMART READ DATA
  c8 00 28 20 d5 b4 e5 00	  00:30:36.550  READ DMA
Error 223 occurred at disk power-on lifetime: 14944 hours (622 days + 16 hours)
  c8 00 08 d8 73 5d e0 00	  00:30:36.549  READ DMA
  c8 00 08 48 5f 55 e0 00	  00:30:36.549  READ DMA
Error 222 occurred at disk power-on lifetime: 14944 hours (622 days + 16 hours)
  c8 00 08 20 7e 54 e0 00	  00:30:36.549  READ DMA
  ca 00 10 90 02 40 e0 00	  00:30:36.549  WRITE DMA
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short captive	   Completed: read failure	   90%	 14944		 95737120
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Can someone help me understand how bad it is?
Morphix
The 000 is the threshold, those are both at 6184.. That's insanely high considering any are not good, but thousands is nuts.
Sent from my LG-H990 using Tapatalk
ggoosen
This is the output from zpool status -v
root@freenas:/mnt/Disk12TB # zpool status -v
  pool: Disk12TB
 state: ONLINE
action: Restore the file in question if possible.  Otherwise restore the
		entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: none requested
		NAME										  STATE	 READ WRITE CKSUM
		Disk12TB									  ONLINE	  43	 0	 0
		  gptid/d40f6179-923a-11e7-bd75-00215ad49ec2  ONLINE	  45	 0	 0
		/var/db/system/syslog-a7c4a4a3d45a4720a1e6b8ad799731fd/log/debug.log
		/var/db/system/rrd-a7c4a4a3d45a4720a1e6b8ad799731fd/freenas.goosen/df-mnt-Disk12TB-D1WindowsDS/df_complex-free.rrd
		Disk12TB/jails/sickrage_1:<0x0>
		/mnt/Disk12TB/d1unixds/movies/A Dark Song (2016)
		Disk12TB/jails/plexmediaserver_1:<0x0>
  pool: Disk21TB
 state: ONLINE
		Disk21TB									  ONLINE	   0	 0	 0
		  gptid/eda92b7b-923a-11e7-bd75-00215ad49ec2  ONLINE	   0	 0	 0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h2m with 0 errors on Wed Sep  6 03:47:03 2017
		freenas-boot  ONLINE	   0	 0	 0
		  da0p2	 ONLINE	   0	 0	 0
ggoosen
Ok so safe to assume this drive is pretty much rubbish, and i shouldnt use it.
I should have also said this is a test system, i pulled the drive from an external USB drive and configured it with no redundancy.
Only data on there are some jails that i setup (any easy way to backup those so i dont have to redo them) if not.. it doesnt matter i can just recreate.
rs225
You could try upgrading the single disk to a mirror, which apparently has to be done manually from the command line. Whatever data is damaged will still be damaged though.
