HDD problem or not?
ajschot
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Green
Device Model:	 WDC WD40EZRX-00SPEB0
Serial Number:	WD-WCC4E1174874
LU WWN Device Id: 5 0014ee 209dda498
Firmware Version: 80.00A80
User Capacity:	4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Sun Oct 14 12:42:29 2018 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
Self-test execution status:	  (   0)	The previous self-test routine completed
					been run.
data collection:		 (54000) seconds.
capabilities:			 (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:			(0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:		(0x01)	Error logging supported.
Short self-test routine
recommended polling time:	 (   2) minutes.
Extended self-test routine
recommended polling time:	 ( 540) minutes.
Conveyance self-test routine
recommended polling time:	 (   5) minutes.
SCT capabilities:		   (0x7035)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   175   171   021	Pre-fail  Always	   -	   8216
  4 Start_Stop_Count		0x0032   080   080   000	Old_age   Always	   -	   20824
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   100   253   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   23072
 10 Spin_Retry_Count		0x0032   100   100   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   100   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   728
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   242
193 Load_Cycle_Count		0x0032   189   189   000	Old_age   Always	   -	   33988
194 Temperature_Celsius	 0x0022   115   099   000	Old_age   Always	   -	   37
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   200   200   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   3
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
SMART Error Log Version: 1
ATA Error Count: 10 (device log contains only the most recent five errors)
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Error 10 occurred at disk power-on lifetime: 988 hours (41 days + 4 hours)
  ER ST SC SN CL CH DH
  04 51 01 00 00 00 a0  Error: ABRT
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  b0 d6 01 e0 4f c2 a0 00	  00:01:42.872  SMART WRITE LOG
  b0 d6 01 e0 4f c2 a0 00	  00:01:42.858  SMART WRITE LOG
  80 45 01 01 44 57 a0 00	  00:01:42.848  [VENDOR SPECIFIC]
  ec 44 01 01 00 00 a0 00	  00:01:42.797  IDENTIFY DEVICE
  80 44 10 00 44 57 a0 00	  00:01:24.545  [VENDOR SPECIFIC]
Error 9 occurred at disk power-on lifetime: 988 hours (41 days + 4 hours)
  b0 d6 01 e0 4f c2 a0 00	  00:01:24.541  SMART WRITE LOG
Error 8 occurred at disk power-on lifetime: 988 hours (41 days + 4 hours)
  b0 d6 01 e0 4f c2 a0 00	  00:01:24.527  SMART WRITE LOG
  b0 d6 01 e0 4f c2 a0 00	  00:01:24.510  SMART WRITE LOG
  b0 d6 01 e0 4f c2 a0 00	  00:01:24.500  SMART WRITE LOG
  80 45 01 01 44 57 a0 00	  00:01:24.497  [VENDOR SPECIFIC]
Error 7 occurred at disk power-on lifetime: 988 hours (41 days + 4 hours)
  ec 44 01 01 00 00 a0 00	  00:01:24.446  IDENTIFY DEVICE
Error 6 occurred at disk power-on lifetime: 988 hours (41 days + 4 hours)
  80 44 10 00 44 57 a0 00	  00:00:52.074  [VENDOR SPECIFIC]
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	 22813		 -
# 2  Short offline	   Completed without error	   00%	 22587		 -
# 3  Short offline	   Completed without error	   00%	 22331		 -
# 4  Short offline	   Completed without error	   00%	 22012		 -
# 5  Short offline	   Completed without error	   00%	 21820		 -
# 6  Short offline	   Completed without error	   00%	 21378		 -
# 7  Short offline	   Completed without error	   00%	 21237		 -
# 8  Short offline	   Completed without error	   00%	 21069		 -
# 9  Short offline	   Completed without error	   00%	 20984		 -
#10  Short offline	   Completed without error	   00%	 20816		 -
#11  Short offline	   Completed without error	   00%	 20648		 -
#12  Short offline	   Completed without error	   00%	 20545		 -
#13  Short offline	   Completed without error	   00%	 20410		 -
#14  Short offline	   Completed without error	   00%	 20254		 -
#15  Short offline	   Completed without error	   00%	 19994		 -
#16  Short offline	   Completed without error	   00%	 19832		 -
#17  Short offline	   Completed without error	   00%	 19664		 -
#18  Short offline	   Completed without error	   00%	 19504		 -
#19  Short offline	   Completed without error	   00%	 19336		 -
#20  Short offline	   Completed without error	   00%	 19168		 -
#21  Short offline	   Completed without error	   00%	 19000		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
root@freenas:~ #
I found a lot topics about "The status of volume Data is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected."
But, i tried to find which disk is giving errors, also the volume is not degraded, the repot above is the drive that only gives me some errors. The thing is, i think it is not that bad right? it was an idle error i think?
I really don't undestand the error is there somebody so kind to tell me what is wrong? And is there a way to reset this error to see if it will come back or not?
This error came after i had changed the power settings of the drives.
Jailer
Not strong, but bad
You're not running long smart tests. Run a long smart test on all your drives and check them again.
joeschmuck
Old Man
I can't figure out what the periodicity is for the Short Tests, they vary widely. I'd recommend running a daily Short Test and a weekly Long Test, since your long test takes 9 hours you should choose a start time conducive with minimal usage of FreeNAS or it will just take a bit longer to complete.
As for errors, look at ID 199 UDMA_CRC_Error_Count = 3, this typically indicates a suspect SATA data cable issue, typically not an internal hard drive error.
Look at the Hard Drive Troubleshooting link in my signature, it may help.
ajschot
Thank you Joe, that is a releave i will check the cable's i resently moved the machine because i was cleanig the room were the freenas stands. I will check the cables and run a long test.
ajschot
i am a noob, i know, and i never digg into this because i had 1 bad disk and that was easy to find out... now... i did a long test but how can i obtain a report?
I got a critical message in freenas gui looks about the same, with a short test have the same results show, but how to get the repot of the long test...
I will try to replace the HBA card, i had problems with one before and just pulled it off and slide it in back and it worked again i think it is the same card so i think the card is bad (got it second hand).
Redcoat
ajschot
For SMART test info, including how to get the report opf your long test go here https://forums.freenas.org/index.ph...bleshooting-guide-all-versions-of-freenas.17/
I know that checked that already but there is not written how to get the report from a long test....
3)  Once the period of time has lapsed for the testing, obtain a SMART Status Result and return to the troubleshooting text.
if i do a -H i just get... PASSED, not anymore info, there must be a way to get a report from a long test....
joeschmuck
Old Man
smartctl -a /dev/ada1 for example. I never use the "-H" parameter, it's not a true representation of the drive health.
The "report" for the long test will appear together the the other results here:
joeschmuck
Old Man
I want to see the entire output from the command I listed above. It's fine to see that the long test passed but I want to see if someting new showed up in the ID's as well.
BigDave
FreeNAS Enthusiast
Chris Moore
if i do a -H i just get... PASSED, not any more info, there must be a way to get a report from a long test....
That is not what you are supposed to do anyhow. I have seen drives with thousands of bad sectors still report that they "PASSED". You need to be looking at the full report by giving the command smartctl -x /dev/ada1
