scottmaverick
- Aug 24, 2016
I have posted this same problem in the installation/updates forum as well, but I believe it might belong here instead.
I get the below error whenever I try to either install or update to 11.2 stable. Currently I am running 9.10.2.U6 without issues. I looked into 11.2 and it did not seem as though there would be any updating 9.10 to 11.2. The issue I keep running into is with one of my ZFS pools and is described below. It looks like it cannot load the pool for some reason, but I cant fingure out why. It should not be changing the ZFS filesystem when I update to 11.2, so I don't think that is the cause. For some reason it says the pool is not supported in 11.2 but it is in 9.10 and when I am upgrading it should not be changing anything about ZFS. The pool consists of 2 vdev's with 12 drives each, 3 of which are redundancy. It shows up as healthy in 9.10 and none of the drives gives any errors in SMART tests. Do I need to somehow update or upgrade the 9.10 pools to be able to use them with 11.2, or is there some other error?
gptzfsboot: error 32 lba 1
error 1 lba 1654253898819624
failed to clear pad2 area of primary vdev
failed to read pad2 area of primary vdev
ZFS: i/o error - all block copies unavailable
ZFS: pool Media is not supported
gptzfsboot: failed to mount default pool media
FreeBSD/x86 boot
Default: Media:
boot:
FreeBSD/x86 boot
Default: Media:
boot:
