wombat-fertilizer
- Mar 15, 2018
Long time, first time...
<TLDR>: (resolved?) I had an unavailable disk after upgrading and then reverting an HBA
It feels like I didn't recover this correctly. Another reboot doesn't show any problems at all...
I have been having
Anyway,
I attempted to replace it via the gui, which i really didn't think would work:
But now it shows that its ok?
ada1
aka gptid/2725ca3e-3817-11e7-8768-00400510e336
. I "replaced" it via the GUI, traceback occurred, but drive rejoined the vdev raidz2-1
without being resilvered. It feels like I didn't recover this correctly. Another reboot doesn't show any problems at all...
- So am I ok here? What should I test, if anything, to be sure?
- Is there anything I should have done differently?
- Why is the drive listed as
ada1p2
instead of its gptid? Can and/or should I fix it?
I have been having
ada1: corrupt or invalid GPT detected.
for a while now. I tried recover on multiple occasions without success. Skipping ahead, I tried upgrading a HighPoint RocketRaid 1640 (PCI) with a HighPoint RocketRaid 2220 (PCI-X in a PCI-X slot). FreeNAS generated all kinds of errors and timeouts accessing any drive connected to it. I did some research, but not a bunch. I tried the card in an Ubuntu box with similar results. Maybe it's the card....Anyway,
ada1
just so happened to one of the drives attached to the new card. I have reverted to the previous working hardware config (nothing else changed), but now ada1
is barely recognized by the system:Code:
grep ada1 /var/log/messages Mar 15 14:13:10 cobalt ada1 at ata3 bus 0 scbus1 target 0 lun 0 Mar 15 14:13:10 cobalt ada1: Serial Number xxxxxxxx Mar 15 14:13:10 cobalt ada1: 100.000MB/s transfers Mar 15 14:13:10 cobalt ada1: 1430799MB (2930277168 512 byte sectors) Mar 15 14:13:10 cobalt GEOM: ada1: corrupt or invalid GPT detected. Mar 15 14:13:10 cobalt GEOM: ada1: GPT rejected -- may not be recoverable. <This is where I replaced the disk in the gui with the existing disk> Mar 15 14:33:11 cobalt GEOM: ada1: corrupt or invalid GPT detected. Mar 15 14:33:11 cobalt GEOM: ada1: GPT rejected -- may not be recoverable. Mar 15 14:33:11 cobalt notifier: dd: /dev/ada1: short write on character device Mar 15 14:33:11 cobalt notifier: dd: /dev/ada1: end of device
pool: vol250x8 state: DEGRADED status: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Attach the missing device and online it using 'zpool online'. see: http://illumos.org/msg/ZFS-8000-2Q scan: resilvered 0 in 0 days 00:00:01 with 0 errors on Thu Mar 15 14:12:51 2018 config: NAME STATE READ WRITE CKSUM vol250x8 DEGRADED 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/e91da02e-8f3e-11e7-acc3-0024817b9c4a ONLINE 0 0 0 gptid/8ac0a1cb-8f3e-11e7-acc3-0024817b9c4a ONLINE 0 0 0 gptid/4eb11777-94f6-11e7-97f0-0024817b9c4a ONLINE 0 0 0 gptid/bbbb5823-8f9a-11e7-b9cd-0024817b9c4a ONLINE 0 0 0 raidz2-1 DEGRADED 0 0 0 13858242310574651614 UNAVAIL 0 0 0 <cont.> was /dev/gptid/2725ca3e-3817-11e7-8768-00400510e336 gptid/38fca8e5-3845-11e7-aaa2-00400510e336 ONLINE 0 0 0 gptid/9cf019e0-3826-11e7-b8d8-00400510e336 ONLINE 0 0 0 gptid/429b5349-3839-11e7-b829-00400510e336 ONLINE 0 0 0
Exception Type: MiddlewareError at /storage/zpool-vol250x8/disk/replace/13858242310574651614/ Exception Value: [MiddlewareError: Disk replacement failed: <cont.> "cannot open 'gptid/14a830fb-2890-11e8-b895-0024817b9c4a': <cont.> no such GEOM provider, must be a full path or shorthand device name, "]
pool: vol250x8 state: ONLINE scan: resilvered 4K in 0 days 00:00:01 with 0 errors on Thu Mar 15 14:33:25 2018 config: NAME STATE READ WRITE CKSUM vol250x8 ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/e91da02e-8f3e-11e7-acc3-0024817b9c4a ONLINE 0 0 0 gptid/8ac0a1cb-8f3e-11e7-acc3-0024817b9c4a ONLINE 0 0 0 gptid/4eb11777-94f6-11e7-97f0-0024817b9c4a ONLINE 0 0 0 gptid/bbbb5823-8f9a-11e7-b9cd-0024817b9c4a ONLINE 0 0 0 raidz2-1 ONLINE 0 0 0 ada1p2 ONLINE 0 0 0 gptid/38fca8e5-3845-11e7-aaa2-00400510e336 ONLINE 0 0 0 gptid/9cf019e0-3826-11e7-b8d8-00400510e336 ONLINE 0 0 0 gptid/429b5349-3839-11e7-b829-00400510e336 ONLINE 0 0 0 errors: No known data errors
