FTP for novice (acces hdd/ folder)
Fester182
(sorry for my english)
I have TrueNAS version TrueNAS-12.0-U7
I have two HDD
/mnt/DATA is hdd where install TrueNAS.
/mnt/DATA2TB is data hdd where i download any files.
I am novice on TrueNAS. I allow service FTP. I create dataset (name is "FTP") on my hdd (/mnt/DATA2TB) where i download any files. Next I create new user "userftp" and set home folder (home folder is folder, if i create dataset "FTP" /mnt/DATA2TB/FTP) I set all permission. FTP work fine.
My question is :how i acces user "userftp" to my all DATA2TB. If i set home directorny HDD (/mnt/DATA2TB) i see error "The specified path is a ZFS pool mountpoint"
I hope you understand me.
Very Thanks.
Not if you did it right. That's where your jails are, so you have another TrueNAS install disk that isn't listed in Storage | Pools (which is normal and good)
OK.
It sounds like something you shouldn't do then... why are you changing it from something that you already said is working?
Fester182
I need set this folder where i have All my download files acces for FTP user.
Or you could move all the files to the FTP access location instead...
Please what i must do :) thanks
Set the home folder to something else that's at least one level below the pool root dataset... like /mnt/DATA2TB/anything
Can i mount /mnt/DATA2TB to /mnt/DATA2TB/FTP ?
no, since that would create a circular reference, but you could make a link to a specific directory from it.
Fester182
okay i got it. i create new folder on DATA2TB name "DATA" next i copy all my files to this folder and i set this folder as home folder for user userftp.
