FTP Issue when creating folder "ftp 550 /testdirectory: Operation not permitted"
tbaror
Hello All,
We have FreeNas hosting FTP for external users and in the same time same dataset is used as cifs sharing for our local users.
We cannot separate the two dataset since they used for common data exchange , ftp users can uploads files delete files download , only folder creation is not working when trying to upload or create folder users get following error below , any idea how to solve this issue ?
Please advise
Thanks
anodos
Sambassador
Hello All,
Please advise
Thanks
Your FTP client is probably trying to change posix mode bits during folder creation. These operations aren't permitted on "windows" datasets because they have a tendency to corrupt the ACLs set on samba shares.
If this is in a testing environment (not production) then you can verify by typing "zfs set aclmode=passthrough <pool>/<dataset>". Once you have confirmed or disconfirmed this hypothesis, set the aclmode back to restricted by typing "zfs set aclmode=restricted <pool>/<dataset>".
tbaror
Yes that's works (its production) , can i take the risk and use it?
Thanks
anodos
Sambassador
Thanks
I've had problems with permissions getting broken while using "aclmode=passthrough" in a production AD environment. My guess is that iXsystems also encountered this and therefore changed the aclmode property on windows shares to "restricted". Officially, using "windows" permissions type on datasets that are Samba shares is the only "supported" configuration. In other words, this is known to break permissions and bug reports will probably be ignored.
BTW, the samba project also advises turning off oplocks on shares that are also accessed via NFS, FTP, or locally.
anodos
Sambassador
Another option may be to configure your ftp server to prevent chmod. I haven't messed with proftpd (which I assume is what FreeNAS uses), but you might be able to add the following parameter:
<Limit SITE_CHMOD>
DenyAll
</Limit>
The reasoning behind this suggestion is that things work better if the service doesn't allow clients to try something that they can't do.
