FTP Directory
Paul Strout
Hello I would like to back up my Machine Images via Internal Filezilla FTP, Permissions is not a concern. I seem to get to this default directory which I assume is root.
I can't leave this directory or go up a level the same problem exist in WinSCP as well.
The share is a SMB so that is probably where the issue resides. I'm leaving out a setting in FreeNas somewhere or need to create a data set of sorts.
Thanks,
Paul
pasiz
On Services -> FTP Settings (wrench icon), there is a path. Check that it corresponds your directory you want to share.
Paul Strout
Hello and Thanks, that was set for the correct path It is a SMB share so I'm not sure why.. I am logged on anonymous as it is a security is not an issue as it is inside. I also adjusted it on Filezilla FTPDirectory.JPG
pasiz
What are you trying to accomplish? Windows can mount SMB directly, so why filezilla? WinSCP is for sftp connections, not for SMB.
Paul Strout
I want to backup machine images( Clones) from a FreeNas Box to a Windows share. Simple FTP seems to be the fastest internally, I am open to any ideas.
Thanks.
pasiz
Thanks.
Maybe return to fundamentals. FTP is configured via services -> FTP, smb has nothing to do with it. Filezilla is for ftp connections, so to use FTP, you setup a FTP server on freenas like suggested. Otherwise use windows built-in sharing to connect your freenas.
Paul Strout
Yes, I want to make this simple I was using Cobain as a Free backup,but would receive random errors or time outs.... FTP was much faster the backups don't need to be time stamped, I would prefer not to map any drives if possible with all of the ransom ware out there.
Thanks,
