freenas vm question on a dell r710
RJGamer1002
so i install window 10 as a vm on my freenas server and i notice that the vm was ruining very slow. i'm not sure if it the GPU in the server can not handle window 10 or it something else with the hardware on the server or it something with freenas-11.2-RELEASE. does anybody know why my window 10 vm ruining very slow?
chris crude
How many CPU cores and how much RAM are you giving the VM?
Also, Win10 works best when you add VirtIO NIC driver, and set the FreeNAS to use VirtIO NIC, not the default Intel.
RJGamer1002
i have given it around 2 -4 cpu cores and about 4 gb of ram i can give it more if i wont to. i have not try virtlO NIC yet but i will try it out.
Chris Moore
There is no passing a GPU to a VM running under FreeNAS.
Hardware details. Please see this post for guidance:
Updated Forum Rules 12/5/18
https://forums.freenas.org/index.php?threads/updated-forum-rules-12-5-18.45124/
RJGamer1002
I put my hardware details in signature for you
Chris Moore
raid controller: Perc 6i Controller with Battery - all drive a on a raid 0 by them self.
That would be a reason for the system to be slow. That is not a supported hardware configuration.
No hardware RAID controller should ever be used with FreeNAS.
You probably need to go back and review the documentation:
https://www.ixsystems.com/documentation/freenas/11.2/freenas.html
Slideshow explaining VDev, zpool, ZIL and L2ARC
https://forums.freenas.org/index.ph...ning-vdev-zpool-zil-and-l2arc-for-noobs.7775/
Terminology and Abbreviations Primer
https://forums.freenas.org/index.php?threads/terminology-and-abbreviations-primer.28174/
Why not to use RAID-5 or RAIDz1
https://www.zdnet.com/article/why-raid-5-stops-working-in-2009/
FreeNAS® Quick Hardware Guide
https://forums.freenas.org/index.php?resources/freenas®-quick-hardware-guide.7/
Hardware Recommendations Guide Rev 1e) 2017-05-06
https://forums.freenas.org/index.php?resources/hardware-recommendations-guide.12/
RJGamer1002
I was thinking about getting a Dell perc h700 raid controler would that fix the problem?
Chris Moore
RJGamer1002
So, what should I get/do to fix this issue?
