FreeNAS upsmon: Poll UPS
BerryPlay
I have a problem with my PowerWalker VI 600 UPS. When the UPS is connected to my Server, after a while I get the following message:
FreeNAS upsmon[15307]: Poll UPS [PowerWalker_UPS] failed - Driver not connected
PowerWalker_UPS is the name I specified in the UPS service section. I am running the latest stable version of FreeNAS 11.1.
wblock
Documentation Engineer
Is the USB cable connected directly, or through a hub? Or is it USB?
BerryPlay
The USP is connected via USB directly to the Server.
ethereal
BerryPlay
ethereal
go to services - ups - settings and click OK
this should restart the config
BerryPlay
ethereal
try a different cable
ethereal
try restarting the ups service
ethereal
do you have the ups service set to the correct port?
BerryPlay
I tried a different cable, but after a while I get the error:
FreeNAS upsd[9717]: Can't connect to UPS [PowerWalker_UPS] (blazer_usb-PowerWalker_UPS): No such file or directory
Followed by the same as before:
ethereal
BerryPlay
BerryPlay
Does no one else has any solution? I am really desperate at the moment.
Redcoat
When you connected the USB cable to the USB port on your server, did you get a message on the console display in the FreeNAS GUI that identified a /dev/ugen or /dev/uhid device name in the console messages?
BerryPlay
When I plug in the UPS i get the following message:
ugen0.5: <INNO TECH USB to Serial> at usbus0
Redcoat
OK. And not that it may be critical, but ugen0.5 is the option you selected in the UPS service configuration screen?
You say "after a while" you get the "not connected" messages - how long is "a while"?
BerryPlay
Sure, I selected ugen0.5 in the UPS configuration. The messages appears after about 5-10 minutes.
Redcoat
And did you try all the other options?
I'm confused by the 5-10 minutes - my system notifies immediately (less than a minute I guess) if connection is lost. I'm not sure I understand the potential significance of what you are experiencing though - have you talked to "Powerwalker"?
BerryPlay
I don't think it makes any sense to select other /dev/ugen*.
