RandomTask
- Jul 8, 2016
I have a FreeNAS 9.2-RELEASE-p12 box that has stopped being able to see anything on the local network (let alone the internet at large).
This box has a static IP: 192.168.2.248.
It is directly connected to a router (192.168.2.1) via an ethernet cable.
The router is serving out IPs from 192.168.2.2 to 192.168.2.100 via DHCP. There are other devices with static IPs outside that range that have access to the network and internet via this router, they are unaffected.
Attempting to ping either the router or Google results in no packets being received:
I've gone through the automated setup to remove and re-add my interface "em0" but I still can't see anything on my local network or the internet.
Here's the contents of my /etc/resolv.conf:
and the contents of my /etc/rc.conf file:
The output from ifconfig:
Any help would be much appreciated! I'm typically a fairly decent Linux guy, but am slowly learning the nuances of BSD!
# ping -c 3 192.168.2.1 PING 192.168.2.1 (192.168.2.1): 56 data bytes --- 192.168.2.1 ping statistics --- 3 packets transmitted, 0 packets received, 100.0% packet loss # ping -c 3 www.google.ca #Obviously this will fail now, but the error is different ping: cannot resolve www.google.ca: Host name lookup failure
search local # Is this maybe the culprit? nameserver 192.168.2.1 # I added this just in case nameserver 8.8.8.8 nameserver 8.8.4.4
#!/bin/sh hostname="Hades" sshd_enable="YES" sendmail_enable="NONE" background_fsck="NO" fsck_y_enable="YES" synchronous_dhclient="YES" ntpd_enable="YES" ntpd_sync_on_start="YES" vmware_guest_vmblock_enable="YES" vmware_guest_vmhgfs_enable="YES" vmware_guest_vmmemctl_enable="YES" vmware_guest_vmxnet_enable="YES" vmware_guestd_enable="YES" syslogd_flags="-s -C" devfs_system_ruleset="usbrules" clear_tmp_X="NO" ataidle_enable="YES" geli_autodetach="NO" dumpdev="AUTO" dumpdir="/data/crash" ix_textdump_enable="YES" early_kld_list="geom_stripe geom_raid3 geom_raid5 geom_gate geom_multipath" kld_list="dtraceall if_cxgbe" pbid_enable="YES" dbus_enable="YES" mdnsd_enable="YES" watchdogd_enable="YES" performance_cpu_freq="HIGH" vboxnet_enable="YES" local_startup="/etc/ix.rc.d /usr/local/etc/rc.d" early_late_divider="*" nginx_enable="YES"
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISE,SIMPLEX,MULTICAST> metric 0 mtu 1500
       options=42098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWTSO>
       ether 90:2b:34:56:3f:56
       inet 192.168.2.248 net mask 0xffffff00 broadcast 192.168.2.255
       media: Ethernet autoselect
       status: no carrier
alc0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
       options=c3198<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TS04,WOL_MCAST,WOL_MAGIC,VLAN_HWTSO,LINKSTATE>
       ether 90:2b:34:56:3f:46
       media: Ethernet autoselect (none)
       status: no carrier
ipfw0: flags=8800<SIMPLEX,MULTICAST> metric 0 mtu 65536
       options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
       inet6 ::1 prefixlen 128
       inet6 fe80::1%lo0 prefixlen 64 scooped 0x6
       inet 127.0.0.1 net mask 0xff000000
bridge0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
       ether 02:94:eb:53:ce:00
       manage 20 holdcnt 6 proto stp maxaddr 2000 timeout 1200
       member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
              ifmaxaddr 0 port 9 priority 128 path cost 2000
       member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
              ifmaxaddr 0 port 8 priority 128 path cost 2000
       member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
              ifmaxaddr 0 port 1 priority 128 path cost 2000000
epair0a: flags=8942<BROADCAST,RUNNING,PROMISE,SIMPLEX,MULTICAST> metric 0 mtu 1500
       options=8<VLAN_MTU>
       ether 02:45:90:00:08:0a
       status: active
epair1a: flags=8942<BROADCAST,RUNNING,PROMISE,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
       ether 02:aa:ac:00:09:0a
       status: active
