[FreeNAS 9 Plugin] - MineOS
Joshua Parker Ruehlig
Nope. It says
ln: /usr/local/lib/librsync.so.1: File exists
Maybe I'm running it from the wrong location? I'm opening the shell on the jail and running the code. That's the correct location, right?
Yeah you should be running this command from within the jail.
Weird that it's there, but mineos still complains about it.
Can you try this
ls -l /usr/local/lib/librsync.so.1
Can you also try the commands '/usr/pbi/mineos-amd64/bin/rsync' and '/usr/pbi/mineos-amd64/bin/rdiff-backup'
Rogallaig
Checking the permissions on the file:
lrwxr-xr-x 1 root wheel 39 Feb 8 21:28 /usr/local/lib/librsync.so.1 -> /usr/pbi/mineos-amd64/lib/librsync.so.1
Perhaps it doesn't like that root has ownership of some files, while I'm logged into the server (and creating restore points) as mcserver?
The rsync command errors out, and the command options scroll by and eventually ends in:
rsync error: syntax or usage error (code 1) at main.c(1559) [client=3.1.1]
Next I ran the rdiff-backup command:
root@mineos_1:/ # /usr/pbi/mineos-amd64/bin/rdiff-backup
  File "/usr/pbi/mineos-amd64/bin/rdiff-backup", line 20, in <module>
    import rdiff_backup.Main
  File "/usr/pbi/mineos-amd64/lib/python2.7/site-packages/rdiff_backup/Main.py", line 25, in <module>
    import Globals, Time, SetConnections, selection, robust, rpath, \
  File "/usr/pbi/mineos-amd64/lib/python2.7/site-packages/rdiff_backup/SetConnections.py", line 30, in <module>
    import Globals, connection, rpath
  File "/usr/pbi/mineos-amd64/lib/python2.7/site-packages/rdiff_backup/connection.py", line 539, in <module>
    import Globals, Time, Rdiff, Hardlink, FilenameMapping, C, Security, \
  File "/usr/pbi/mineos-amd64/lib/python2.7/site-packages/rdiff_backup/Rdiff.py", line 22, in <module>
    import os, librsync
  File "/usr/pbi/mineos-amd64/lib/python2.7/site-packages/rdiff_backup/librsync.py", line 28, in <module>
    import _librsync
ImportError: Shared object "librsync.so.1" not found, required by "_librsync.so"
    import os, librsync
    import _librsync
root ownership is as expected for system libraries.
Ok, the rsync command worked as expected.
Maybe the lib that is supposed to be linked to doesn't exist anymore? What does this give you?
ls -l /usr/pbi/mineos-amd64/lib/librsync.so.1
Rogallaig
Here's the results of the command:
root@mineos_1:/ # ls -l /usr/pbi/mineos-amd64/lib/librsync.so.1
lrwxr-xr-x 1 root wheel 17 Sep 18 00:51 /usr/pbi/mineos-amd64/lib/librsync.so
.1 -> librsync.so.1.0.2
And here's the info on librsync.so.1.0.2:
root@mineos_1:/ # ls -l /usr/pbi/mineos-amd64/lib/librsync.so.1.0.2
-rwxrwxr-x 1 mcserver wheel 50080 Sep 18 00:51 /usr/pbi/mineos-amd64/lib/libr
sync.so.1.0.2
Should librsync.so.1 be linked to librsync.so.1.0.2 ?? They have the same timestamp, so I'm a little confused.
sync.so.1.0.2
Yes that's how shared libraries usually work. A lot of symlinks until you get to the actual lib version.
What's strange is the settings of librsync.so.1.0.2, it's owned by mcserver and has very open 775 permissions. You might try settings this to the same as the rest of the directory, probably root:wheel 644. But maybe the for got overwritten looking at those weird permission levels.
ElGusto
Hello!
I am trying FreeNAS 9.3 and the MineOS plugin at the moment. When I first installed the plugin, it worked normally, but I noticed it had installed the jail directory onto my z2pool. I wanted it to install on the additional SSD-Volume I also have.
So I uninstalled the plugin, changed the Jail path in general configuration, deleted the old jail directory and installed the plugin again.
But the plugin doesn't show up under installed plugins.
I tried changing the jail location to the z2pool again and the plugin installation worked.
But it won't work with the changed jail path.
What could I do about this?
Thank you!
Hello!
I am trying FreeNAS and the MineOS plugin at the moment. When I first installed the plugin, it worked normally, but I noticed it had installed the jail directory onto my z2pool. I wanted it to install onto the additional SSD-Volume I have. So I uninstalled the plugin, changed the Jail path in general configuration, deletet the old jail directory and installed the plugin again.
Thank you!
this doesn't sound specific to mineos. can you install any jails to your ssd pool?
ElGusto
Yes, I installed the Couchpotato and the Headphone plugin, just for trying.
They are both working with the SSD-jail path.
Does the plugin have a check for free space or similar?
I have just about 12GByte free on the SSD-pool.
on your ssd pool was a jail created for mineos, how about a dataset?
if not, please try again and see what, if anything is created.
ElGusto
There's a jail called:
mineos_1
And there are two datasets:
jails/.warden-template-pluginjail
jails/mineos_1
It's all on the SSD-pool.
But the entry at Plugins/Installed is not there. (unlike it is when using the z2pool on my harddisks)
Some pictures, in case I'm wrong somehow:
mineos_1
jails/mineos_1
sounds like something went wrong part way during the install. I would try again just to double check.
I think 12GB should be enough, but the install of java and python with mineos does take a few GB.
ElGusto
I already installed and uninstalled the plugin three times on both pools. I have also rebootet FreeNAS in between. But it was the same everytime.
As I'm new to FreeNAS, I have just added two pictures to my previous post, in case I am misinterpreting this Information.
it looks like the jail did install but I'm guessing something got messed up during plugin installation. please download the mineos PBI from download.freenas.org, and upload it to your mineos jail.
ElGusto
Ok, I did so. It is working now!
Thank you for the super fast help! :)
Though, I wonder what has gone wrong?
Wouldn't reinstalling the plugin from the list download and install it all again? What's the difference when downloading it manually and transferring to the jail?
I deleted the jail after every try before...
Is there a cache or some temporary storage involved that I could clean, for preventing potential problems?
installing from the repo always installs a new jail. uploading a pbi can be to a new jail or in this case an already created jail.
maybe creating the jail+installing the pbi somehow was timing out on your system. Im not sure if PBIs are locally cached.
rcdevils
Hello, I'm a bit of a newbie so I will apologize in advanced if the solution to my question is obvious.
Write now I'm trying to get HTTPS working for the mineos web GUI but it doesnt work for me, even though I have checked the box to "Enable SSL:" and generated a key and CRT from star SSL and installed them into the /etc/ssl/certs/.
With https enabled whenever I try to access the webgui it just times out.
Any help would be appreciated. :)
EDIT
I read this post http://discourse.codeemo.com/t/ssl-error-with-private-certificate/403/7
So the solution was for me to create the csr and private key inside the jail using openssl then submitting the csr to startssl. Then with the crt given by startssl and key created by openssl it all worked.
When you enabled SSL did you also specify your cert+key?
rcdevils
Yes, I named the crt and key mineos so that the default directory is correct.
I recommend trying to restart the plugin.
If that still doesn't work I would ask on the MineOS forum.
