FreeNAS 9.2.1.6-RC2 is now available
C
Craig Rodrigues
Guest
FreeNAS 9.2.1.6-RC2 is available here
All bugs fixed in FreeNAS 9.2.1.6-RC can be found here.
The major items of interest are mentioned in the ReleaseNotes here.
These items include:
  • Samba is updated to 4.1.9
  • Netatalk is updated to 3.1.2
  • Several fixes related to the System Dataset
  • A new VirtualBox jail template
  • Several fixes related to ZFS replication
  • A new mpr driver, officially sanctioned by LSI, for the LSI 12 Gbps SAS HBA
  • An experimental in-kernel iSCSI target
  • A .usb file which can be imaged to a USB key. This can be used for installing FreeNAS from a USB key.
  • various iSCSI fixes
  • scponly shell has been fixed
  • SMB2 protocol is the default for CIFS shares
  • VirtualBox template updated to 4.3.12
Since the last 9.2.1.6-RC, additional items have been fixed including:
  • Samba updated from 4.1.8 to 4.1.9
  • Security fixes in file(1) and libmagic(3), and gss_pseudo_random interoperability issue. CVE-2013-7345, CVE-2014-1943, CVE-2014-2270, [EN-14:08]
  • other fixes
Please provide feedback on this RC. If no major problems are found, we will release 9.2.1.6-RELEASE in approximately 14 days.
Thank you for testing FreeNAS!
- The FreeNAS Development Team
Sir.Robin
Upgraded both systems. Seems fine :) Thanx!
ThreeDee
It's like Christmas .. we got this update and I see an update for Plex too . .as well .. also ..
Again, Thanks!
ThreeDee
that's odd..? After update to RC2, Plex update isn't there now.. 9.9.7.429 is what I have, and I could of sworn it was showing something something 5 hundred something (I don't remember exact number now) prior to updating to RC2 .. :confused:
joeschmuck
Old Man
ThreeDee
Magnus33
Update went fine all working smooth.
As for plex i filed a bug report about it being several versions out of date and they updated shortly after.
You want something updated you need to file a bug report and there very good at doing the needed updates.
Scareh
yup the plex update worked. Had to turn off plex pluging to update as it failed to do so the first time, and on top it took me more or less an hour before it actually finished but hey, it worked so no complaining here ^^
Thomymaster
Hmm i don't think the issue you posted above is the same. In your case CIFS transfers kill an NFS datastore. In my case the performance via ISCSI for my ESXI 5.5 datastore is very low. Attached is a screenshot showing the high latency within the vSphere client. So my question is what has changed regarding ISCSI in 9.2.1.6rc2 (i don't use the new experimental ISCSI target)?
Thomymaster
You said
"I'm on 9.2.1.3 and it does this. I think it has been a problem for a while...."
But i don't really understand what you want to dell me....
