FreeNAS 11.0-U2 bhyve networking and virtualbox issues
thorn57
So I have two problems:
1: After upgrading to 11 virtualbox vms wont start anymore. I only get this error message: "The virtual machine '2dts' has terminated unexpectedly during startup with exit code 1"
2: Using bhyve I managed to get a win 10 vm working but even though i installed the virtio drivers vor the NIC I am unable to connect to the network
m0nkey_
VirtualBox VMs are not supported under FreeNAS 11 as Bhyve and VirtualBox kernel modules conflict.
thorn57
All right, then I'll be using bhyve Vbox was not optimal anyways. But as described above i can't get networking to work in my windows 10 vm with the virtio NIC
thorn57
Do you mean the driver version?
Looking at the driver details in windows it says it's version 100.73.104.12600 from the 11 August 2016 from Red Hat, Inc and it is from the virtio-win-0.1.1 iso I downloaded from their homepage
