reidara
- Aug 4, 2012
I decided to change train from 9.10 Stable to 9.10 Nightlies....
After that Virtualbox plugin dont work... I can access the webgui of virtualbox , but the VMs wont start:
I get this error: The virtual machine 'test' has terminated unexpectedly during startup with exit code 1
and this :
Exception Object
[message:protected] => The virtual machine 'test' has terminated unexpectedly during startup with exit code 1
[string:Exception:private] =>
[code:protected] => 0
[file:protected] => /usr/local/www/phpvirtualbox/lib/vboxconnector.php
[line:protected] => 2382
[trace:Exception:private] => Array
[0] => Array
[line] => 928
[function] => remote_progressGet
[class] => vboxconnector
[type] => ->
[args] => Array
[0] => Array
[progress] => 5107891f2cbf9bef-000000000000042b
[_persist] => Array
[vboxHandle] => 5107891f2cbf9bef-0000000000000429
[fn] => progressGet
[1] => Array
=> /usr/local/www/phpvirtualbox/lib/ajax.php
[line] => 309
[function] => __call
[type] => ->
[args] => Array
[0] => progressGet
[1] => Array
[0] => Array
[_persist] => Array
[fn] => progressGet
[1] => Array
[0] => Array
[data] => Array
[responseData] => Array
[info] => Array
[completed] => 1
[canceled] =>
[description] => Starting VM
[operationDescription] => Creating process for virtual machine "test" (headless)
[timeRemaining] => Array
[timeElapsed] => Array
[days] => 16981
[hours] => 17
[minutes] => 12
[seconds] => 10
[percent] => 0
[success] => 1
[key] => 53474945cfd7ac0bf8114767c209c2a6
[errors] => Array
[persist] => Array
[messages] => Array
[2] => Array
[line] => 309
[function] => progressGet
[type] => ->
[args] => Array
[0] => Array
[_persist] => Array
[fn] => progressGet
[1] => Array
[0] => Array
[data] => Array
[info] => Array
[completed] => 1
[canceled] =>
[days] => 16981
[hours] => 17
[minutes] => 12
[seconds] => 10
[percent] => 0
[success] => 1
[errors] => Array
[persist] => Array
[messages] => Array
[previous:Exception:private] =>
What to do ?
and this :
Exception Object
[0] => Array
[line] => 928
[type] => ->
[args] => Array
[0] => Array
[_persist] => Array
[fn] => progressGet
[1] => Array
[line] => 309
[type] => ->
[args] => Array
[0] => progressGet
[1] => Array
[0] => Array
[_persist] => Array
[fn] => progressGet
[1] => Array
[0] => Array
[data] => Array
[info] => Array
[completed] => 1
[canceled] =>
[days] => 16981
[hours] => 17
[minutes] => 12
[seconds] => 10
[percent] => 0
[success] => 1
[errors] => Array
[persist] => Array
[messages] => Array
[2] => Array
[line] => 309
[type] => ->
[args] => Array
[0] => Array
[_persist] => Array
[fn] => progressGet
[1] => Array
[0] => Array
[data] => Array
[info] => Array
[completed] => 1
[canceled] =>
[days] => 16981
[hours] => 17
[minutes] => 12
[seconds] => 10
[percent] => 0
[success] => 1
[errors] => Array
[persist] => Array
[messages] => Array
What to do ?
