rafadavidc
- Mar 26, 2016
I have two different VirtualBox jails, and both of them aren't starting their VMs. I've included below what I'm getting when I try. Should I roll back, or is this an easy fix?
Exception Object ( [message:protected] => The virtual machine 'TS3' has terminated unexpectedly during startup with exit code 1 [string:Exception:private] => [code:protected] => 0 [file:protected] => /usr/local/www/phpvirtualbox/lib/vboxconnector.php [line:protected] => 2382 [trace:Exception:private] => Array ( [0] => Array ( => /usr/local/www/phpvirtualbox/lib/vboxconnector.php [line] => 928 [function] => remote_progressGet [class] => vboxconnector [type] => -> [args] => Array ( [0] => Array ( [progress] => 560f593db05c544a-0000000000000040 [_persist] => Array ( [vboxHandle] => 560f593db05c544a-000000000000003e ) [fn] => progressGet ) ) ) [1] => Array ( => /usr/local/www/phpvirtualbox/lib/ajax.php [line] => 309 [function] => __call [class] => vboxconnector [type] => -> [args] => Array ( [0] => progressGet [1] => Array ( [0] => Array ( [progress] => 560f593db05c544a-0000000000000040 [_persist] => Array ( [vboxHandle] => 560f593db05c544a-000000000000003e ) [fn] => progressGet ) [1] => Array ( [0] => Array ( [data] => Array ( [responseData] => Array ( [progress] => 560f593db05c544a-0000000000000040 [info] => Array ( [completed] => 1 [canceled] => [description] => Starting VM [operationDescription] => Creating process for virtual machine "TS3" (headless) [timeRemaining] => Array ( ) [timeElapsed] => Array ( [days] => 17076 [hours] => 19 [minutes] => 17 [seconds] => 22 ) [percent] => 0 ) ) [success] => 1 [key] => 53474945cfd7ac0bf8114767c209c2a6 ) [errors] => Array ( ) [persist] => Array ( ) [messages] => Array ( ) ) ) ) ) ) [2] => Array ( => /usr/local/www/phpvirtualbox/lib/ajax.php [line] => 309 [function] => progressGet [class] => vboxconnector [type] => -> [args] => Array ( [0] => Array ( [progress] => 560f593db05c544a-0000000000000040 [_persist] => Array ( [vboxHandle] => 560f593db05c544a-000000000000003e ) [fn] => progressGet ) [1] => Array ( [0] => Array ( [data] => Array ( [responseData] => Array ( [progress] => 560f593db05c544a-0000000000000040 [info] => Array ( [completed] => 1 [canceled] => [description] => Starting VM [operationDescription] => Creating process for virtual machine "TS3" (headless) [timeRemaining] => Array ( ) [timeElapsed] => Array ( [days] => 17076 [hours] => 19 [minutes] => 17 [seconds] => 22 ) [percent] => 0 ) ) [success] => 1 [key] => 53474945cfd7ac0bf8114767c209c2a6 ) [errors] => Array ( ) [persist] => Array ( ) [messages] => Array ( ) ) ) ) ) ) [previous:Exception:private] => )
Exception Object ( [message:protected] => The virtual machine 'MineOS' has terminated unexpectedly during startup with exit code 1 [string:Exception:private] => [code:protected] => 0 [file:protected] => /usr/local/www/phpvirtualbox/lib/vboxconnector.php [line:protected] => 2382 [trace:Exception:private] => Array ( [0] => Array ( => /usr/local/www/phpvirtualbox/lib/vboxconnector.php [line] => 928 [function] => remote_progressGet [class] => vboxconnector [type] => -> [args] => Array ( [0] => Array ( [progress] => 89460e9c48f17391-0000000000000040 [_persist] => Array ( [vboxHandle] => 89460e9c48f17391-000000000000003e ) [fn] => progressGet ) ) ) [1] => Array ( => /usr/local/www/phpvirtualbox/lib/ajax.php [line] => 309 [function] => __call [class] => vboxconnector [type] => -> [args] => Array ( [0] => progressGet [1] => Array ( [0] => Array ( [progress] => 89460e9c48f17391-0000000000000040 [_persist] => Array ( [vboxHandle] => 89460e9c48f17391-000000000000003e ) [fn] => progressGet ) [1] => Array ( [0] => Array ( [data] => Array ( [responseData] => Array ( [progress] => 89460e9c48f17391-0000000000000040 [info] => Array ( [completed] => 1 [canceled] => [description] => Starting VM [operationDescription] => Creating process for virtual machine "MineOS" (headless) [timeRemaining] => Array ( ) [timeElapsed] => Array ( [days] => 17076 [hours] => 19 [minutes] => 15 [seconds] => 45 ) [percent] => 0 ) ) [success] => 1 [key] => 53474945cfd7ac0bf8114767c209c2a6 ) [errors] => Array ( ) [persist] => Array ( ) [messages] => Array ( ) ) ) ) ) ) [2] => Array ( => /usr/local/www/phpvirtualbox/lib/ajax.php [line] => 309 [function] => progressGet [class] => vboxconnector [type] => -> [args] => Array ( [0] => Array ( [progress] => 89460e9c48f17391-0000000000000040 [_persist] => Array ( [vboxHandle] => 89460e9c48f17391-000000000000003e ) [fn] => progressGet ) [1] => Array ( [0] => Array ( [data] => Array ( [responseData] => Array ( [progress] => 89460e9c48f17391-0000000000000040 [info] => Array ( [completed] => 1 [canceled] => [description] => Starting VM [operationDescription] => Creating process for virtual machine "MineOS" (headless) [timeRemaining] => Array ( ) [timeElapsed] => Array ( [days] => 17076 [hours] => 19 [minutes] => 15 [seconds] => 45 ) [percent] => 0 ) ) [success] => 1 [key] => 53474945cfd7ac0bf8114767c209c2a6 ) [errors] => Array ( ) [persist] => Array ( ) [messages] => Array ( ) ) ) ) ) ) [previous:Exception:private] => )
