I have been working on my build, which slowly but surely is getting there.
I'm using the Fractal Define R6 case; which comes with 3 x 3-pin fans.
I'm also using a Noctua NH-U9DX i4 processor cooler - which comes with 2 x 4pin Noctua fans.
Based on what I have read, it looks like 3 pin fans will run at full speed on these supermicro boards.
My questions
Thanks!
R. Rod
My questions
- For those using this case. Are you using the fan hub that comes with the case? Or are you connecting your fans directly to one of the many fan ports on the board?
- Is there a way I can drive the fan speeds on the processor cooler by the processor temperature?
- I know these wouldn't support it, but if I decide to swap the OEM fans with Noctua PWM fans, can I drive these case fans by the HDD temps?
Thanks!
R. Rod
