Fractal Design Node 304 Fan Controller Question
chrisolson09
Hey all,
I'm in the process of building my first freenas and am super excited! I'll admit I'm a newbie when it comes to building machines and was hoping you guys could help me out. My NAS specs are:
Node 304 Case
Seasonic G series 450 Modular
Supermicro Xeon D 1521 combo
Noctua CPU fan
The problem i'm running into is with the fans connections. The case comes with a fan controller but there is no plugs on the power supply to plug in the 4 pin molex connector to power case fan controller.
The motherboard has 4 fan headers but some things I've read seem to indicate that the Node 304 fans cannot be controlled by the motherboard so they have replaced the stock fans with Noctua PWM fans and use a script to control the fans (which is something that seems way out of my league).
I'd really appreciate any insight you guys could give me on understanding the best way for me to connect these case fans! Thanks!
Chris
SweetAndLow
Sweet'NASty
You can connect and fan to the motherboard. Just plug them into the fan headers.
chrisolson09
Really that’s it?? That’s how I have it now but from the things I’ve read I wasn’t sure.
Does it matter that the fans plugs are 3 pin the motherboard fan headers are 4 pin?
MrToddsFriends
Documentation Browser
This thread contains a very instructive Node 304 / Xeon D build report (original fans replaced by 4-pin Noctua fans controlled by the mainboard).
https://forums.freenas.org/index.ph...node-304-x10sdv-tln4f-esxi-freenas-aio.57116/
I'm using a Node 304 case with Noctua fans, too, with only 3 fans (of total 4, including CPU) controlled by the motherboard (Avoton here, not Xeon D, exhaust fan controlled by Node 304).
MrToddsFriends
A few additional words: Check your motherboard manual for compatibility of 4-pin fan headers with 3-pin (oder 2-pin) fans. 4-pin fans use an additional PWM signal for speed control while 2-pin and 3-pin fans are controlled by voltage. Pin #3 is used for a tachometer signal.
https://en.wikipedia.org/wiki/Computer_fan#Connectors
chrisolson09
Thanks MrToddsFriends! I really appreciate the input. I did find that thread you referenced and its been really useful to me. I got a little stuck on the fan part though cause I haven't replaced the fans with Noctua (I think that's the route I'll have to go).
On your build you said the Exhaust fan is controlled by the Node 304, how is that powered? My seasonic power supply doesn't have a 4 pin molex connection that is needed for the Node 304 fan controller??
chrisolson09
So it looks like I might have found a solution. I found this adapter that I think could be use to run from the remaining 4pin 12 power connector on my power supply to the molex connector of the case.
https://www.amazon.com/4-pin-Power-Connector-Molex-Adapter/dp/B005L8Z16Y
Do you guys have any recommendations on which you feel is better? I could go this adapter route and then use the manual controller on the case or I could swap out the fans on the case for Nocutua's and have them controlled by the motherboard. What are you thoughts?
SweetAndLow
Sweet'NASty
The motherboard might not control the speed correctly. But either way works. My node 304 gaming build uses the fan controller mainly because I didn't have enough headers on my motherboard. I just set it on medium and have never touched it.
dmitrios
I suppose the only reason for the extra expense to replace the already included Fractal's Silent Series R2 140mm and R2 92mm fans with Noctua's A14 and A9 PWM respectively is PWM. Otherwise they appear to me very similar spec-wise.
However unless one is a fan (pun intended) of the beige/brown - Nanoxia DS would be a better upgrade:
https://www.quietpc.com/140mmfans
https://www.quietpc.com/92mmfans
MrToddsFriends
Yes, of course. Using fan controller scripts (or even monitoring fan speed) isn't possible with the standard two-pin Fractal Design fans.
Stux
I found I had to run the system fans at too high a speed (too noisy) to cope with worst case heat generation.
And actually the front fans didn’t, iirc.
Fan control was the solution. And upgrading the fans.
moelassus
MrToddsFriends
The front fans of my Node 304 didn't start in the low position of the fan controller switch.
Unfortunately the beautiful beige/brown Noctua fans are hidden as long as the Node 304 top cover is closed. :)
Stux
Other thing is, if you do use the same fans as I used, with an X10SDV board, you should be able to use the exact same fan script and config settings as I used and get a "it just works" result.
dmitrios
Noctua makes black fans too if you're not into the beige/brown theme.
They also make the "Redux" versions of the famous beige/brown ones, which looks rather good in grey. I was too lazy to search for what that means in practice.
The Reduxes are old models, sold without accessories and in grey.
MrToddsFriends
They say "starting voltage <6" on the official spec. The switch gives 5v at the Low setting.
Which tells us that the 92mm Silent Series R2 fans might work at the 5V fan controller position or not. Of course I did read the Fractal Design manuals and spec sheets back then.
