mka
- Sep 26, 2013
I'm using an Intel S1200RPS mainboard on a FreeNAS server and noticed, while the CPU fans quickly reduce their speed/rpm after booting windows (with the same board), they stay at topspeed when using FreeNAS. I've added into the BIOS to power down fan speed as much as possible (silent operation) but the mainboard won't unless booting up Windows; the fans are three 4PIN PWM Fans 120mm, 1xCPU, 2xSYS (HDD bay).
Is it possible to control the fan speeds somehow from within FreeNAS? Very low speed would suffice since the system is remaining quiet cool even without a fan. But I do want low or (better) smart adjusted fan speed.
Thank you! :)
Thank you! :)
