flyingpengwin
- Sep 26, 2013
Hello All,
I have a X10SLM-F-O SuperMicro board that I've connected PWM fans to. I've followed the Kevin Horton's guide Here and I've searched both in the forums and online but I cannot find a solution. When I type in the terminal any ipmitool raw command, nothing ever "sticks". Right now in IPMI web gui, I have the fan mode set to FULL as per Kevin's instructions. So currentrly ipmitool sdr | grep FAN returns all the fans are spinning at max RPM. If I do "ipmitool raw 0x30 0x70 0x66 0x01 0x00 0x32" or "ipmitool raw 0x30 0x70 0x66 0x01 0x00 50" then the fans speeds drop and I can see this in ipmitool sdr. But then after about 8 seconds, the fans speed back up to 100%. Does anyone have any suggestions?
Thanks!
Thanks!
