_Will_
- Jun 11, 2014
The i3 should be enough if you only transcode one thing at a time. If you buy the boxed version of whatever processor you choose, the stock cooler is enough (if you buy the tray version, you need to supply your own cooler).
I don't see a situation where I'll be transcoding more than one Blu Ray at a time. If the i3 will work in this scenario, then I will start looking at i3 compatible hardware and compare pricing to the Xeon setup I listed above.
