I'm woring on a new build, just trying to decide the hardware, I'm basically looking for a nas that will serve 2 or 3 users max..
I don't want to go for the cheapest option but not looking at the most expensive setup possible, specially because the usage will be moderate/low. I will be storing important files so I want something reliable, somewhere between recommended settings and high end hardware..
- What's the recommended motherboard?
- Recommended RAM?
- For hdd, is it better to have the same storage for all drives? e.g. 2 x 4tb VS 1 x 4tb + 2 x 2tb? Does it make a difference?
- I'm planning to go for WD 3tb red.. Anyone here had any issues with them? Should I go for 2tb or 4tb instead?
Thanks!
- Recommended RAM?
Thanks!
