First time M1015
LSI is now part of Avago, it seems, and they demand that I register -- but I have to select a product category to which I want access, and there is no category that I recognize as covering HBAs
woah...thats weird, ok let me see if i can find it another way
  • 9211_8i_Package_P16_IR_IT_Firmware_BIOS_for_MSDOS_Windows.zip
Z300M
Thanks for the speedy response -- but it's actually P20 I need now to keep the latest FreeNAS 9.3(.1?) update, with its P20 drivers, happy.
The 9211-8i driver is for the M1015, right? What about the driver for the SAS 2308 controller that's incorporated into the X10SL7-F motherboard?
If you have those P20 drivers -- for either DOS or UEFI -- I'd be very grateful.
Here you are. And yes, both i provided i have seen used for the M1015, for the onboard SAS you have i am not sure
  • 9211_8i_Package_P20_IR_IT_Firmware_BIOS_for_MSDOS_Windows.zip
Supermicro provides the firmware. I can't find it at the moment, so I recommend you get in touch with their support and ask for P20 IT mode.
