Where is the megarec Utility to Crossflash M1015 to IT Mode?
Some manufacturers are idiots and don't include an EFI shell executable in the BIOS. That is easily fixed by acquiring such an executable and booting it from a USB flash drive, as you did.
Fidget08
Well, I finally got it. I just needed some sleep and some food. I copied all required files to the USB stick but for the life of me I couldn't get it to boot into EFI. After a little looking around I could this:
Note: If you are unable to launch UEFI Shell from the firmware directly using any of the above mentioned methods, create a FAT32 USB pen drive with Shell.efi copied as (USB)/efi/boot/bootx64.efi. This USB should come up in the firmware boot menu. Launching this option will launch the UEFI Shell for you.
That worked perfectly. I was able to boot into the shell and upgrade the firmware. Thanks for the help.
