First NAS. First NAS Build.
Stux
I hope it wont be a problem for a 12 drive pool with 8 Seagates and 4 WDs?
It’ll be fine. How are you structuring the pool?
rajy3k
Earlier I was thinking about ZFS1. However after looking at the badblocks testing I am convinced about ZFS2.
Sent from my Pixel using Tapatalk
Stux
12 way RaidZ1. Definitely a bad idea.
12 way RaidZ2, a little bit too wide.
rajy3k
My bad! I meant RAIDZ2.
What do you think will be the right thing then? I am not too sure that I need more than 2 disks of redundancy, however, I am a complete novice here and suggestions are welcome.
Also, on some of the disks badblocks testing is done. There is nothing other than 0 in 3 of the critical parameterers. However I am continuously getting "Failed SMART usage Attribute: 5 Reallocated_Sector_Ct" message. on it. Also I am getting huge values under RAW Value field for the two categories, namely "Raw_Read_Error_Rate" and "Seek_Error_Rate". Did I do something wrong?
Stux
I wouldn't use more than 10 disks in a RaidZ2 vdev.
So, you could go with 2x 6-way RaidZ2, but that will mean 4 disks of parity, which you might not like.
Reallocated sector count. This should not happen on a new disk, thus the disk is broken/damaged and you should RMA it.
Normal for Seagate drives. Seagate drives encode the total number of reads and seeks into these values.
rajy3k
Two of the HDDs (Both Seagate IronWolf 4Tb drives) are yet to finish testing for bad blocks after 115 hours. And because of the error messages, I am not able to understand what is the progress level.
Is it normal to take so long for testing?
dezufnoC
Sooooooo.... getting back to the OP! I just purchased the HPE ProLiant ML10 and am now waiting for the rest of the parts to show up including the memory and drives. I read in another post about peeps adding fans to this box. Is it really necessary? I plan to have (4) 4TB WD Red drives.
fr33n0zeer
I have read that the HPE tower has poor airflow. I have five WD Red 4TB 5400 RPM drives and an SSD for the boot drive. This is the max number of drives this case can handle. And to do this I would have needed to purchase a hard drive enablement kit which cost about $70. I decided to get a Fractal Design Define R5 Blackout Silent tower for $90 with free shipping and a new power supply. The Fractal Design case comes equipped with eight 3.5" drive bays, two SSD drive bays, and two 5 1/4" drive bays. And the airflow is very good with this case. It comes with two 140 mm fans, with the capacity to add a bunch more. So, that's my solution.
