SeaWolfX
- Mar 14, 2018
Hi guys,
So I have been putting this on hold for a while, but I am finally planning on building my first FreeNAS server. I have some requirements for the server and I although I have read up on some stuff I would like to check with you guys here if everything is feasible with FreeNAS and get any comments/feedback you might have. I would also like your input on hardware selection. I typically overkill and would really appreciate any input you might have so that I do not overspend on unnecessary specs. E.g. memory type / how much, do I need read/write cache, motherboard etc.?
It is going to be a family server primarily used for media streaming and as a file server. There will be a common storage space (min. 10 TB, with option for future expansion) for media (movies, music, pictures, books, etc.) as well as personal storage spaces (min. 100 GB) for each member. Although not a primary objective I am planning for it to maybe host a couple if Windows/Linux VMs of a separate SSD disk. The server will be located at a location with internet speed 500/500. Both common and personal directories should be able to be mapped as "network drives" on the users personal computers outside the server local network, so that file handling can be done as if the user was operating on folders on the local computer (what solutions are available for this?).
Main objectives:
- Media Server (streaming HD movies and music) via Plex
- VM
- File Server
- Data Integrity & Backup
Number of users:
Total: 8
Max simultaneous access: 3-4 (e.g. streaming movies / transferring files)
Hardware:
I based my suggestions below on the FreeNAS recommendations and it will probably set me back around $2400 which is bit more than I was aiming for. So If you have some suggestions on what I might cut back on I would really appreciate it. Keep in mind that I would like the setup to be a bit flexible with regards to future expansions / upgrades. Cabinet and PSU i have from before.
Motherboard
Supermicro X11SSH-F
Processor
Intel Xeon E3-1230v6 3,5GHz Socket 1151 Tray
Memory
Crucial DDR4 2400MHz ECC 2x16GB (CT2K16G4WFD824A)
Harddrives
4 x WD Red WD60EFRX 64MB 6TB
1 x Samsung SSD 256 GB
UPS
APC Back-UPS Pro BR900GI
(for safe shutdown on power-loss)
Main objectives:
- VM
- File Server
Number of users:
Total: 8
Hardware:
Motherboard
Supermicro X11SSH-F
Processor
Memory
Harddrives
UPS
