DaneJa
- Mar 14, 2015
Firstly, thanks for all the great info you all provide. I've spent the last couple months in my limited free time gradually combing through the manual, hardware guide sticky, and the forums. Good stuff. I'll try to keep this short.
This will be my first FreeNAS build. Currently I have a Drobo with 5x6TB WD Red HDDs in it. It became clear some time ago that I needed to step up to the next level, but I've just been buying larger HDDs until I could devote some time to researching all this stuff.
Existing Hardware
Obviously the build is pretty much straight out of the hardware recommendations sticky. The reason I'm bugging you all about this is two-fold.
Thanks again for your help! Looks like I've failed in keeping it short...
Existing Hardware
- Juniper EX2200-24T-4G switch
- Server Technology CW-8H1 switching power distribution unit with expansion unit
- IOGear CGL1808 LCD combo KVM
- All required storage HDD’s
- Storage server for media. Will be encoding media to stream to remote locations. I anticipate no more than 2-3 streams at any one time. Must be able to do this while extracting/compressing and error checking files.
- Battery backup solution commensurate with hardware power draw.
- Cabinet to house hardware.
- All hardware should be a silent as possible.
- FreeNAS array: Initially 6x2TB HDDs in a RAIDZ2 VDev to familiarize myself with the software. To be expanded to 4 Z2 VDevs of 6 drives before moving my data over, allowing future expansion by upgrading the smallest vdev.
- Chassis: SuperMicro SC846E16-R1200B 24 Bay 4U Chassis 2x 1200Watt PSU
- MB: SuperMicro X9SRH-7F-O
- CPU: Intel Xeon E5-1620v2
- RAM: Crucial 32GB (2 x 16 GB) ECC Registered DDR3 1600 Model CT2K16G3ERSLD4160B
- The first concern I have is that I'm neglecting the newest generation of hardware. Is there any feature that I'll find myself wishing I had in a year or two if I stick with the X9 that I would have had with an X10? Any reason I should upgrade the CPU?
- The second reason I'm here is that I'd like to solicit your opinions on server cabinets and battery backups. I'm looking for a cabinet in the ballpark of 24U, ideally with a glass/plexi front, lockable, presentable as it will be in my house, and as silent as possible. The options I've been able to find have been staggeringly expensive. Lastly, if you have any recommendations for a battery backup that will allow my hardware time to safely shut down, I'd greatly appreciate reading them.
