Faulted disk but no smart errors/ZFS states it DEGRADED
MrUnknownEMC
Hi, i just got email regarding one of my ZFS array, at first i thought my drive had died. After stopping my server and remove the affect drive to check if it works on another computer. It worked perfectly and i check smart data and show no problem/errors. It is problem the drive? Should i replace it ASAP? So I rebooted back into freenas and re check the cable and found out the drive show up again on drives list. Could the problem be the power cable? Maybe the drive power cycled?
My ZFS results:
 zpool status
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h6m with 0 errors on Fri Oct 27 03:51:05 2017
		NAME		STATE	 READ WRITE CKSUM
		freenas-boot  ONLINE	   0	 0	 0
		  da0p2	 ONLINE	   0	 0	 0
errors: No known data errors
  pool: volume1
 state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
		the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
  scan: scrub repaired 0 in 4h48m with 0 errors on Sun Oct  8 04:48:49 2017
		volume1											 DEGRADED	 0	 0																						  0
		  mirror-0										  DEGRADED	 0	 0																						  0
			4410447761725274727							 UNAVAIL	  0	 0																						  0  was /dev/gptid/35a61c0a-c77a-11e6-8a11-3085a991bbbd.eli
			gptid/369808cc-c77a-11e6-8a11-3085a991bbbd.eli  ONLINE	   0	 0																						  0
  pool: volume2
 state: ONLINE
  scan: scrub repaired 0 in 3h47m with 0 errors on Sun Oct  1 03:47:39 2017
		volume2											 ONLINE	   0	 0																						  0
		  mirror-0										  ONLINE	   0	 0																						  0
			gptid/9674e2bf-44d9-11e7-9dc9-3085a991bbbd.eli  ONLINE	   0	 0																						  0
			gptid/9741d636-44d9-11e7-9dc9-3085a991bbbd.eli  ONLINE	   0	 0																						  0
My short smart logs on the affect drive.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Red
Device Model:	 WDC WD20EFRX-68EUZN0
Serial Number:	WD-WCAZAL399204
LU WWN Device Id: 5 0014ee 2081f3d29
Firmware Version: 51.0AB51
User Capacity:	2,000,398,934,016 bytes [2.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:	Fri Nov  3 14:08:21 2017 AEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
										was suspended by an interrupting command from host.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(37680) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 363) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x3035) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   189   162   021	Pre-fail  Always	   -	   5516
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   176
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   080   080   000	Old_age   Always	   -	   14810
 10 Spin_Retry_Count		0x0032   100   100   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   100   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   176
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   98
193 Load_Cycle_Count		0x0032   001   001   000	Old_age   Always	   -	   938614
194 Temperature_Celsius	 0x0022   115   105   000	Old_age   Always	   -	   35
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   200   200   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	 14796		 -
# 2  Short offline	   Completed without error	   00%	 14772		 -
# 3  Extended offline	Interrupted (host reset)	  60%	 14750		 -
# 4  Short offline	   Completed without error	   00%	 14724		 -
# 5  Short offline	   Completed without error	   00%	 14700		 -
# 6  Short offline	   Completed without error	   00%	 14676		 -
# 7  Short offline	   Completed without error	   00%	 14652		 -
# 8  Short offline	   Completed without error	   00%	 14628		 -
# 9  Short offline	   Completed without error	   00%	 14604		 -
#10  Short offline	   Completed without error	   00%	 14580		 -
#11  Short offline	   Completed without error	   00%	 14556		 -
#12  Extended offline	Completed without error	   00%	 14539		 -
#13  Short offline	   Completed without error	   00%	 14508		 -
#14  Short offline	   Completed without error	   00%	 14485		 -
#15  Short offline	   Completed without error	   00%	 14461		 -
#16  Short offline	   Completed without error	   00%	 14437		 -
#17  Short offline	   Completed without error	   00%	 14413		 -
#18  Short offline	   Completed without error	   00%	 14389		 -
#19  Short offline	   Completed without error	   00%	 14364		 -
#20  Short offline	   Completed without error	   00%	 14340		 -
#21  Short offline	   Completed without error	   00%	 14316		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
MrUnknownEMC
  pool: freenas-boot
state: ONLINE
		  da0p2	 ONLINE	   0	 0	 0
  pool: volume1
state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
		attempt was made to correct the error.  Applications are unaffected.
   see: http://illumos.org/msg/ZFS-8000-9P
  scan: resilvered 139M in 0h0m with 0 errors on Fri Nov  3 14:31:21 2017
		volume1											 ONLINE	   0	 0																																								  0
			gptid/35a61c0a-c77a-11e6-8a11-3085a991bbbd.eli  ONLINE	   0	 0																																								 23
  pool: volume2
state: ONLINE
So after a remounted the array/volume i get a different error. From what i believed there is nothing wrong with my drive. What should i do next? Should i replace the drive with new drive or just zpool clear and use existing drive?
SweetAndLow
Sweet'NASty
Hardware specs? Freenas version? Read the rules
This drive has significant lcc values. You need to wdidle it.
MrUnknownEMC
Freenas Version: FreeNAS-11.0-U4 (54848d13b)
CPU: Fx6300
RAM: 16GB DDR3
Hard Drives: 2x2TB WD REDs 2x4TB SEAGATE IRONWOLF
I have switch out the sata data cable and reset the ZFS pool. I will scrub/check again tonight see if the error reappear.
...which will do nothing about the load cycle count of nearly 1M. That's already well over the drive's lifetime spec. WDIDLE will keep the number from increasing (much) in the future.
MrUnknownEMC
How do that? Right now im copying data off to spare drive. I getting new pair of 3TB hopefully next week.
SweetAndLow
Sweet'NASty
CPU: Fx6300
RAM: 16GB DDR3
Hardware specs means what part did you use to make your system. Motherboard, nic, could, psu, memory, hdd controller, case and anything else important.
