rwfitzy
- Nov 20, 2014
I have a FreeNAS 9.3-STABLE I need to update to version 11-STABLE. I found some updates pending and applied, then received this Alert: CRITICAL: Update failed. Check /data/update.failed for further details. Then I found this in the update log...
I found some posts regarding this error and a bug report, but no solution. One suggested to do fresh install and import my zpool. The system boots from USB 8GB flash disk. Can I safely change trains to 11-STABLE to upgrade?
FATAL ERROR - The following SQL query failed: CREATE TABLE "directoryservice_kerberossettings" ("id" integer NOT NULL PRIMARY KEY, "ks_appdefaults_aux" text NOT NULL, "ks_libdefaults_aux" text NOT NULL) The error was: table "directoryservice_kerberossettings" already exists
