SOLVED Failed perc damaged multiple disks, how to fix?
Daisuke
I had a H710 perc that failed in my Dell R720xd. I replaced it with a new one and when I started Scale, the polls were ruined with several platter disks showing as faulted or degraded. Since this is a new setup, there was no data into pools, so I decided to destroy all pools and start over. Re-creating the pool was difficult, I had to wipe each of 12 disks. Once all disks wiped, the pool was created but the disks show the same status, faulty or degraded.
What should I do next, to fix this issue? Is there a command I can run in a Linux livecd to re-format the disks properly? Everything is a mess. I also have 2 SSDs installed that it takes forever to create an applications pool in mirror.
# zpool status default
  pool: default
 state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
    Sufficient replicas exist for the pool to continue functioning in a
    degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
    repaired.
  scan: scrub repaired 180K in 00:01:49 with 0 errors on Tue Jul  5 20:53:30 2022
    NAME                                      STATE     READ WRITE CKSUM
    default                                   DEGRADED     0     0     0
      raidz2-0                                DEGRADED     6   615     0
        a3d8d2ab-ce18-49ba-a3ba-d507ea2815e0  FAULTED      0    16     0  too many errors
        cf639408-92c3-4a06-8613-d93f9cc8e4a2  DEGRADED    21   533     0  too many errors
        cbc5a2eb-4040-40dc-91c2-a74ee19f41c5  FAULTED      0    16     0  too many errors
        9f44f3b4-a512-464d-96a5-70610e763c09  DEGRADED     0   399     1  too many errors
        5b3f653f-2305-4ead-ba3d-637fc733329a  DEGRADED    10   911     4  too many errors
        4aa941bb-b220-4247-9868-213e1d67f8f5  DEGRADED     3   540     4  too many errors
        9a6db0a4-194c-43ee-aa39-551b2f5c8c29  DEGRADED    27   728     6  too many errors
        ff9e7cd4-092e-4618-9640-fe0bc8d5df01  DEGRADED     0   356     2  too many errors
        95d1f7bf-ab78-445e-a90b-36daf692a568  DEGRADED     4   504     6  too many errors
        54b647a2-f0c0-4884-87e8-dcb770b67cb9  DEGRADED     4   578     6  too many errors
        9e04f193-8a1e-42dd-b39b-d308075ba6eb  DEGRADED    15   822     4  too many errors
        0be664b2-2ad4-482b-a402-979e63e8b847  DEGRADED     0   520     1  too many errors
errors: No known data errors
I get tons of errors like:
Samuel Tai
Are you sure the replacement PERC is in IT mode? It's possible your replacement PERC is also bad.
Daisuke
Yes, I flashed the perc to IT mode successfully. If the perc would be defective, I would not see the disks, prior making the pool. When the first perc failed, a big red X was showing next to each pool. Before destroying the pool with new perc installed, it was showing several disks online:
# zpool status -v default
  pool: default
 state: DEGRADED
    degraded state.
    repaired.
  scan: scrub in progress since Tue Jul  5 16:02:18 2022
    166G scanned at 201M/s, 3.49M issued at 4.24K/s, 17.2T total
    8.93M repaired, 0.00% done, no estimated completion time
      raidz2-0                                DEGRADED   273   140     0
        629cefc5-7187-41e3-bd66-d06e7c3707f7  DEGRADED   211   126     0  too many errors  (repairing)
        2c08fe13-bf6b-4af4-8557-d276ec9fb39a  DEGRADED   459   118     0  too many errors  (repairing)
        2a15af88-b984-442b-8c15-4400587c5edb  ONLINE     161    93     0  (repairing)
        9aa9d5f9-40a9-4868-a0ff-c5de94cf6f5d  ONLINE     524   153     0  (repairing)
        419c3bec-fd1a-46b1-96c4-688ca14d9393  DEGRADED   134   132     0  too many errors  (repairing)
        9f176f88-76a2-4617-a008-4ec668c92ee8  ONLINE     195   117     0  (repairing)
        3393954b-c917-49d2-8e1a-ce523005939f  ONLINE     367   122     0  (repairing)
        7beb091a-2b52-4a47-ac40-2f554026d6d7  ONLINE     325   111     0  (repairing)
        44b86a8d-b12b-4e14-8a35-63d62c28cb99  FAULTED      6    10     0  too many errors
        a1320232-66ce-43de-a96f-252284e0933a  FAULTED     10    73     0  too many errors
        993f9da2-b761-4492-8232-4c6584da9d38  DEGRADED   169   129     0  too many errors  (repairing)
        99efdf13-ce7e-4b6e-bf9b-d87704ffaa79  ONLINE     175   119     0  (repairing)
It has be a way to destroy the pool and wipe the disks properly, I don't think the UI is the right choice in my situation.
Samuel Tai
Try reseating the replacement PERC, and cleaning the contacts with alcohol.
Samuel Tai
