Daisuke
- Jun 23, 2011
I had a H710 perc that failed in my Dell R720xd. I replaced it with a new one and when I started Scale, the polls were ruined with several platter disks showing as faulted or degraded. Since this is a new setup, there was no data into pools, so I decided to destroy all pools and start over. Re-creating the pool was difficult, I had to wipe each of 12 disks. Once all disks wiped, the pool was created but the disks show the same status, faulty or degraded.
What should I do next, to fix this issue? Is there a command I can run in a Linux livecd to re-format the disks properly? Everything is a mess. I also have 2 SSDs installed that it takes forever to create an applications pool in mirror.
I get tons of errors like:
# zpool status default pool: default state: DEGRADED status: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Replace the faulted device, or use 'zpool clear' to mark the device repaired. scan: scrub repaired 180K in 00:01:49 with 0 errors on Tue Jul 5 20:53:30 2022 config: NAME STATE READ WRITE CKSUM default DEGRADED 0 0 0 raidz2-0 DEGRADED 6 615 0 a3d8d2ab-ce18-49ba-a3ba-d507ea2815e0 FAULTED 0 16 0 too many errors cf639408-92c3-4a06-8613-d93f9cc8e4a2 DEGRADED 21 533 0 too many errors cbc5a2eb-4040-40dc-91c2-a74ee19f41c5 FAULTED 0 16 0 too many errors 9f44f3b4-a512-464d-96a5-70610e763c09 DEGRADED 0 399 1 too many errors 5b3f653f-2305-4ead-ba3d-637fc733329a DEGRADED 10 911 4 too many errors 4aa941bb-b220-4247-9868-213e1d67f8f5 DEGRADED 3 540 4 too many errors 9a6db0a4-194c-43ee-aa39-551b2f5c8c29 DEGRADED 27 728 6 too many errors ff9e7cd4-092e-4618-9640-fe0bc8d5df01 DEGRADED 0 356 2 too many errors 95d1f7bf-ab78-445e-a90b-36daf692a568 DEGRADED 4 504 6 too many errors 54b647a2-f0c0-4884-87e8-dcb770b67cb9 DEGRADED 4 578 6 too many errors 9e04f193-8a1e-42dd-b39b-d308075ba6eb DEGRADED 15 822 4 too many errors 0be664b2-2ad4-482b-a402-979e63e8b847 DEGRADED 0 520 1 too many errors errors: No known data errors
