I recently encountered some issues with my setup, and unfortunately, my ASRock X570M Pro4 motherboard has failed. I'm currently in a bit of a predicament and would greatly appreciate any guidance or advice you can offer.
Current Setup:
Current Setup:
- Motherboard: ASRock X570M Pro4 (now non-functional)
- Boot Drive: 2 M.2 SSDs configured in RAID
- Storage: One pool consisting of 3 drives
- Data Salvage: Is there a way to salvage the data from my existing setup? Particularly concerned about the data in my 3-drive pool.
- Replacement and Compatibility: If I purchase a new motherboard, can I simply boot from my existing M.2 OS drives? Will this approach allow me to seamlessly access my storage pool, or are there additional steps I need to take?
- Long-Term Solution: I'm looking for a motherboard recommendation that's compatible with my current setup (AM4 socket, micro ATX) and reliable enough to last for the next 5 years. Priorities include stability, support for RAID configuration, and compatibility with TrueNAS.
