SOLVED Expanding Pool does not seem to be updating
dethman
I started with 3x 8TB Disks in Z1, I added a second set of 3x 8TB Disks in Z1. I then selected the Expand Pool option and it says it completed. However, the pool is not showing any additional available space.
I am very new to TrueNAS and not sure if I am somehow doing something wrong. Now when I run
zpool list -v
it does seems to show the correct available space in the pool. I am missing a step, or do I need to reboot after adding the new VDEV? Or did I just mess up and create a raidz1 mirror and did not add any space?
dethman
Neverminded I am a moron and did not look at the numbers correctly. 26.61 is correct for 2x Z1 groups with 3x 7.25TB disk. Sorry once I looked at the reports I can see where the new space was allocated.
