I been searching and cant find any answer to this. About 3 updates back from the current one my Alert icon turned red with the below. I have run smartctl on each and dont see anything standing out. I find it hard to believe that 3 hds are going bad at once. I pulled ada4 which is a 4tb WD green drive only a few months old hooked it up to a windows pc and ran WD software test on it and there was no problem put it back in the freenas box error right away. Ideas? Is there a way to clear these? I did do a clean install of freenas to see if it would help since it was having issues hanging after a update.
Alert
ADA1
Ada3
Ada4
Alert
- CRITICAL: Device: /dev/ada4, 5 Offline uncorrectable sectors
- CRITICAL: Device: /dev/ada3, 1 Currently unreadable (pending) sectors
- CRITICAL: Device: /dev/ada3, 1 Offline uncorrectable sectors
- CRITICAL: Device: /dev/ada1, 669 Currently unreadable (pending) sectors
- CRITICAL: Device: /dev/ada1, 669 Offline uncorrectable sectors
ADA1
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Model Family: Seagate Barracuda LP
Device Model: ST31500541AS
Serial Number:
LU WWN Device Id: 5 000c50 01f0234a6
Firmware Version: CC35
User Capacity: 1,500,301,910,016 bytes [1.50 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5900 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Fri May 15 11:31:32 2015 MDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 643) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 377) minutes.
Conveyance self-test routine
SCT capabilities: (0x103f) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 226176532
3 Spin_Up_Time 0x0003 100 100 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 098 098 020 Old_age Always - 2617
5 Reallocated_Sector_Ct 0x0033 094 094 036 Pre-fail Always - 274
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 8924269380
9 Power_On_Hours 0x0032 051 051 000 Old_age Always - 43530
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 85
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 8590065667
189 High_Fly_Writes 0x003a 094 094 000 Old_age Always - 6
190 Airflow_Temperature_Cel 0x0022 064 052 045 Old_age Always - 36 (Min/Max 33/37)
194 Temperature_Celsius 0x0022 036 048 000 Old_age Always - 36 (0 13 0 0 0)
195 Hardware_ECC_Recovered 0x001a 062 042 000 Old_age Always - 226176532
197 Current_Pending_Sector 0x0012 084 084 000 Old_age Always - 669
198 Offline_Uncorrectable 0x0010 084 084 000 Old_age Offline - 669
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 1
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 35287 (24 91 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 3095822764
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 416316717
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 43514 -
# 2 Short offline Completed without error 00% 43508 -
# 3 Extended offline Completed without error 00% 43372 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Ada3
Model Family: Seagate Barracuda 7200.11
Device Model: ST31000340AS
Serial Number:
LU WWN Device Id: 5 000c50 00e1f7ab2
Firmware Version: SD1A
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Rotation Rate: 7200 rpm
Local Time is: Fri May 15 11:35:41 2015 MDT
been run.
data collection: ( 642) seconds.
Auto Offline data collection on/off supp ort.
command.
power-saving mode.
recommended polling time: ( 233) minutes.
SCT capabilities: (0x103b) SCT Status supported.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 210483155
3 Spin_Up_Time 0x0003 091 081 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 095 095 020 Old_age Always - 5992
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 2
7 Seek_Error_Rate 0x000f 073 060 030 Pre-fail Always - 43151626372
9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 32510
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 19
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 155
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 13
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 060 049 045 Old_age Always - 40 (Min/Max 38/42)
194 Temperature_Celsius 0x0022 040 050 000 Old_age Always - 40 (0 13 0 0 0)
195 Hardware_ECC_Recovered 0x001a 034 019 000 Old_age Always - 210483155
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 1
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error
# 1 Short offline Completed without error 00% 32488 -
# 2 Extended offline Completed: read failure 30% 32348 157 2443678
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.Ada4
Model Family: Western Digital Caviar Green (AF, SATA 6Gb/s)
Device Model: WDC WD40EZRX-00SPEB0
Serial Number:
LU WWN Device Id: 5 0014ee 26038e23b
Firmware Version: 80.00A80
User Capacity: 4,000,753,476,096 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Fri May 15 11:37:43 2015 MDT
been run.
data collection: (50760) seconds.
command.
power-saving mode.
recommended polling time: ( 508) minutes.
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 290
3 Spin_Up_Time 0x0027 207 177 021 Pre-fail Always - 6633
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 27
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 4116
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 27
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 20
193 Load_Cycle_Count 0x0032 187 187 000 Old_age Always - 39350
194 Temperature_Celsius 0x0022 123 109 000 Old_age Always - 29
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 5
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 17
No Errors Logged
# 1 Conveyance offline Completed without error 00% 4071 -
# 2 Conveyance offline Completed: read failure 90% 4071 1803531003
# 3 Extended offline Completed: read failure 90% 4069 1803531000
# 4 Short offline Completed: read failure 90% 4069 1803531001
# 5 Extended offline Completed: read failure 90% 3957 1803531000
# 6 Short offline Completed without error 00% 3622 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
