Errors on HD after updates
Allred
I been searching and cant find any answer to this. About 3 updates back from the current one my Alert icon turned red with the below. I have run smartctl on each and dont see anything standing out. I find it hard to believe that 3 hds are going bad at once. I pulled ada4 which is a 4tb WD green drive only a few months old hooked it up to a windows pc and ran WD software test on it and there was no problem put it back in the freenas box error right away. Ideas? Is there a way to clear these? I did do a clean install of freenas to see if it would help since it was having issues hanging after a update.
Alert
  • CRITICAL: Device: /dev/ada4, 5 Offline uncorrectable sectors
  • CRITICAL: Device: /dev/ada3, 1 Currently unreadable (pending) sectors
  • CRITICAL: Device: /dev/ada3, 1 Offline uncorrectable sectors
  • CRITICAL: Device: /dev/ada1, 669 Currently unreadable (pending) sectors
  • CRITICAL: Device: /dev/ada1, 669 Offline uncorrectable sectors
ADA1
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Model Family:     Seagate Barracuda LP
Device Model:     ST31500541AS
Serial Number:
LU WWN Device Id: 5 000c50 01f0234a6
Firmware Version: CC35
User Capacity:    1,500,301,910,016 bytes [1.50 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    5900 rpm
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Fri May 15 11:31:32 2015 MDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  643) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 377) minutes.
Conveyance self-test routine
SCT capabilities:              (0x103f) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   119   099   006    Pre-fail  Always       -       226176532
  3 Spin_Up_Time            0x0003   100   100   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   098   098   020    Old_age   Always       -       2617
  5 Reallocated_Sector_Ct   0x0033   094   094   036    Pre-fail  Always       -       274
  7 Seek_Error_Rate         0x000f   081   060   030    Pre-fail  Always       -       8924269380
  9 Power_On_Hours          0x0032   051   051   000    Old_age   Always       -       43530
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       85
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       8590065667
189 High_Fly_Writes         0x003a   094   094   000    Old_age   Always       -       6
190 Airflow_Temperature_Cel 0x0022   064   052   045    Old_age   Always       -       36 (Min/Max 33/37)
194 Temperature_Celsius     0x0022   036   048   000    Old_age   Always       -       36 (0 13 0 0 0)
195 Hardware_ECC_Recovered  0x001a   062   042   000    Old_age   Always       -       226176532
197 Current_Pending_Sector  0x0012   084   084   000    Old_age   Always       -       669
198 Offline_Uncorrectable   0x0010   084   084   000    Old_age   Offline      -       669
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       1
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       35287 (24 91 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       3095822764
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       416316717
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     43514         -
# 2  Short offline       Completed without error       00%     43508         -
# 3  Extended offline    Completed without error       00%     43372         -
Ada3
Model Family:     Seagate Barracuda 7200.11
Device Model:     ST31000340AS
Serial Number:
LU WWN Device Id: 5 000c50 00e1f7ab2
Firmware Version: SD1A
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Rotation Rate:    7200 rpm
Local Time is:    Fri May 15 11:35:41 2015 MDT
                                        been run.
data collection:                (  642) seconds.
                                        Auto Offline data collection on/off supp        ort.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 233) minutes.
SCT capabilities:              (0x103b) SCT Status supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_        FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   119   099   006    Pre-fail  Always       -        210483155
  3 Spin_Up_Time            0x0003   091   081   000    Pre-fail  Always       -        0
  4 Start_Stop_Count        0x0032   095   095   020    Old_age   Always       -        5992
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -        2
  7 Seek_Error_Rate         0x000f   073   060   030    Pre-fail  Always       -        43151626372
  9 Power_On_Hours          0x0032   063   063   000    Old_age   Always       -        32510
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -        19
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -        155
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -        13
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -        0
190 Airflow_Temperature_Cel 0x0022   060   049   045    Old_age   Always       -        40 (Min/Max 38/42)
194 Temperature_Celsius     0x0022   040   050   000    Old_age   Always       -        40 (0 13 0 0 0)
195 Hardware_ECC_Recovered  0x001a   034   019   000    Old_age   Always       -        210483155
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -        1
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -        1
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -        0
No Errors Logged
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA        _of_first_error
# 1  Short offline       Completed without error       00%     32488         -
# 2  Extended offline    Completed: read failure       30%     32348         157        2443678
Ada4
Model Family:     Western Digital Caviar Green (AF, SATA 6Gb/s)
Device Model:     WDC WD40EZRX-00SPEB0
Serial Number:
LU WWN Device Id: 5 0014ee 26038e23b
Firmware Version: 80.00A80
User Capacity:    4,000,753,476,096 bytes [4.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Fri May 15 11:37:43 2015 MDT
                                        been run.
data collection:                (50760) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 508) minutes.
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x7035) SCT Status supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       290
  3 Spin_Up_Time            0x0027   207   177   021    Pre-fail  Always       -       6633
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       27
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       4116
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       27
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       20
193 Load_Cycle_Count        0x0032   187   187   000    Old_age   Always       -       39350
194 Temperature_Celsius     0x0022   123   109   000    Old_age   Always       -       29
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       5
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       17
No Errors Logged
# 1  Conveyance offline  Completed without error       00%      4071         -
# 2  Conveyance offline  Completed: read failure       90%      4071         1803531003
# 3  Extended offline    Completed: read failure       90%      4069         1803531000
# 4  Short offline       Completed: read failure       90%      4069         1803531001
# 5  Extended offline    Completed: read failure       90%      3957         1803531000
# 6  Short offline       Completed without error       00%      3622         -
Bidule0hm
Server Electronics Sorcerer
Ada1 is probably failing since at least a few days (and I'd even say a few weeks).
Ada3 is failing since at least 140 hours ago (about 6 days).
Ada4 is failing since about 160 hours ago (about 7 days).
You can't "clear" these errors on the drives. The only thing you can do is replacing the drives. I'd start with ada1 who is in pretty bad shape... the others can wait a bit for now. If you use RAID-Z1 and you don't have a backup then do a backup ASAP.
NB: the copy-paste has failed for ada3, some info is missing (and of course it's the most important...), can you correct this so we can help better?
Allred
Ok here is a redo of ada3. What would cause it I know 2 of the drives are older but for the ada4 that was purchased in Dec to go all of a sudden scares me.
Serial Number:
Local Time is:    Fri May 15 13:16:39 2015 MDT
                                        been run.
                                        command.
                                        power-saving mode.
  1 Raw_Read_Error_Rate     0x000f   119   099   006    Pre-fail  Always       -        217574437
  4 Start_Stop_Count        0x0032   095   095   020    Old_age   Always       -        5994
  7 Seek_Error_Rate         0x000f   073   060   030    Pre-fail  Always       -        43151636809
  9 Power_On_Hours          0x0032   063   063   000    Old_age   Always       -        32511
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -        157
190 Airflow_Temperature_Cel 0x0022   072   049   045    Old_age   Always       -        28 (Min/Max 26/28)
194 Temperature_Celsius     0x0022   028   050   000    Old_age   Always       -        28 (0 13 0 0 0)
195 Hardware_ECC_Recovered  0x001a   034   019   000    Old_age   Always       -        217574437
No Errors Logged
For some reason its cutting off the Raw data but here it is
FAILED RAW_VALUE
Bidule0hm
Bad drives happens (and rough shipping too), did you test the drive right at the beginning?
That disk is very questionable. It has only 1 for item 197, but the #4 is freakin' scary. Generally you'd expect drives to have less than 1000, even after years of use. Yours has almost 6000!
ada1 has a pretty high start/stop count too.
Either those are a symptom of the drive failing or you've been starting/stopping the motor in an effort to save power. If it's the latter, you pretty much have your reason for why the disks are failing. Some of them are fairly old too. :P
Allred
Ok yeah I never turn these off unless there is a power outage or upgrade. What do you think of the Ada4 thats the one thats really worried me I have no clue what all those codes are. Are WD green drives crap? I bought 2 4 tb when the externals were really cheap pulled one out of the case went to the server and the other to my Arcade cabinet. Why would it show ok in windows and not freenas? Thanks for all the help :)
Bidule0hm
More likely a problem with the power connector, some bad contact maybe?
With the greens you'll want to use wdidle3 to avoid the LCC problem, but other than that they are pretty good ;)
