Yesterday I had the 1st critical error. Should I replace the disk or should I repair it and wait how long the next error takes?
What do you think?
Gesendet von meinem A0001 mit Tapatalk
[root@thingtank] ~# smartctl -t short -a /dev/ada0
smartctl 6.4 2015-06-04 r4109 [FreeBSD 10.3-RELEASE amd64] (local build)
Copyright (C) 2002-15, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WMC4N2097349
LU WWN Device Id: 5 0014ee 6043d3d38
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue May 10 10:33:44 2016 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      ( 121) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (39360) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 395) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       4860
  3 Spin_Up_Time            0x0027   200   180   021    Pre-fail  Always       -       4983
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       38
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   199   000    Old_age   Always       -       41
  9 Power_On_Hours          0x0032   075   075   000    Old_age   Always       -       18503
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       38
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       21
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       21
194 Temperature_Celsius     0x0022   119   105   000    Old_age   Always       -       31
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       1
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed: read failure       90%     18502         1597934
# 2  Short offline       Completed without error       00%     18502         -
# 3  Short offline       Completed without error       00%     18070         -
# 4  Short offline       Completed without error       00%     17828         -
# 5  Short offline       Completed without error       00%     17326         -
# 6  Short offline       Completed without error       00%     17087         -
# 7  Short offline       Completed without error       00%     16631         -
# 8  Short offline       Completed without error       00%     16392         -
# 9  Short offline       Completed without error       00%     15888         -
#10  Short offline       Completed without error       00%     15648         -
#11  Short offline       Completed without error       00%     15144         -
#12  Short offline       Completed without error       00%     14905         -
#13  Short offline       Completed without error       00%     14425         -
#14  Short offline       Completed without error       00%     14186         -
#15  Short offline       Completed without error       00%     13681         -
#16  Short offline       Completed without error       00%     13441         -
#17  Short offline       Completed without error       00%     12962         -
#18  Short offline       Completed without error       00%     12722         -
#19  Short offline       Completed without error       00%     12218         -
#20  Short offline       Completed without error       00%     11979         -
#21  Short offline       Completed without error       00%     11475         -
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Short self-test routine immediately in off-line mode".
Drive command "Execute SMART Short self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 2 minutes for test to complete.
Test will complete after Tue May 10 10:35:44 2016
Use smartctl -X to abort test.
What do you think?
