EvanVanVan
- Feb 1, 2014
I just logged on to FreeNAS (trying to track down my Listen Queue Overflow problem) and just noticed a pulsing yellow alert (after upgrading to 9.3 a couple months ago, I finally saw the alert) with two messages:
I'm going with fixing #1 first. I've searched and think I got a handle on it, but I just wanted confirm a couple of things.
1. I'd rather not lose all of my data lol. Shutting down my server and unplugging the breakout cables (2) from the m1015 card, won't cause me to lose my data?
2. I followed the "servethehome" guide when initially cross flashing my m1015 card into LSI9211-it mode. One post I read said I would need to use "Megarec -cleanflash 0" to erase my current (newer) firmware, another I saw said that since I initially used that command I only have to do "sas2flash -o -e 6" (and also the command about my sas address "sas2flash -o -sasadd 500605Bxxxxxxxxx"). Can I use the sas2flash to erase my current firmware?
Thanks
edit: Just to add this, here's what I'm planning to do. I formatted a 8gb usb stick to FAT32 with a MBR, put the p16 firmware (2118it.bin) as well as the p16 UEFI installer(sas2flash.efi) on it. And will run these commands:
WARNING: Firmware version 18 does not match driver version 16 for /dev/mps0 WARNING: New feature flags are available for volume volume1. Refer to the "Upgrading a ZFS Pool" section of the User Guide for instructions.
Thanks
sas2flash -listall to show the controller and verify the current version. sas2flash -o -e 6 to erase the BIOS, do not reboot after this command. sas2flash -o -f 2118it.bin to write the new firmware. sas2flash -o -sasadd 500605Bxxxxxxxxx sas2flash -listall to confirm firmware version
