Not for file storage via SMB.Hello,
So, i've 8x10TB HDD and i wanted to know whether i would need to setup a SLOG device to accelerate the write speeds. I will be using the server for normal Time Machine backup and also some specific video files to it frequently.
Thanks
Thanks for making it clear!Not for file storage via SMB.
Yes, had a confusion ;)If you have to ask, the answer is "no"![]()
So, it is not beneficial for SMB right? Can you please tell me what is syncrhornius writes? I have heard a lot about it.SLOG only has a use for synchronous writes like NFS or iSCSI for VMFS.
Right.So, it is not beneficial for SMB right?
It means the client waits with returning the "write done" back to the application until the server has confirmed that data is committed to disk.Can you please tell me what is syncrhornius writes? I have heard a lot about it.
With synchronous writes you know your data is safe on disk. That's why hypervisors like VMware use it because the guest operating systems themselves cache data in memory and once they write to what they think is a disk they need to rely on the storage system not lying to them.Should i use synchronous or asynchronous write?
ZFS compresses your data on the fly. It's the default. No need to tinker with that.Also, i have heard about compression. Any info that?
NFS sucks even more on the Mac in my experience and various desktop applications like e.g. MS Office might just crash when using files on an NFS volume. Besides if you are thinking about "synchronous writes plus SLOG" ... even with SLOG that will be orders of magnitudes slower than asynchronous.The transfer speeds via SMB is so slow on my Mac. But it is fast on a same speced PC on Windows.
Would it be any better to use NFS instead of SMB?
Thanks man. I was going to buy like 2xOptane 905P for that. I got few $$$ saved :)Right.
Oh, i see. Is this what TrueNAS has by default?It means the client waits with returning the "write done" back to the application until the server has confirmed that data is committed to disk.
Which means it's orders of magnitude slower than asynchronous where the server just commits the data to RAM, acknowledges the write to the client, the client OS says "write OK" to the application and everybody happily moves on. ZFS then commits the data to storage every 5 seconds in what is called a transaction group.
Does that mean one should use synchronous writes for the highest data reliability/integrity?With synchronous writes you know your data is safe on disk.
Wow. I didn't know. You don't know how much Thankful i am for all these :)That's why hypervisors like VMware use it because the guest operating systems themselves cache data in memory and once they write to what they think is a disk they need to rely on the storage system not lying to them.
GotchaZFS compresses your data on the fly. It's the default. No need to tinker with that.
Dang shit.NFS sucks even more on the Mac in my experience and various desktop applications like e.g. MS Office might just crash when using files on an NFS volume.
Bummer. So, the synchronous writes are generally slower than asynchronous writes? What's the default settings provided by TrueNAS? How much is the impact between these two in terms of speed?Besides if you are thinking about "synchronous writes plus SLOG" ... even with SLOG that will be orders of magnitudes slower than asynchronous.
Bingo!You don't want synchronous writes unless you are hosting VMs.
Yes. The default is asynchronous for SMB and synchronous for iSCSI. I don't know from the top of my head for NFS what the default is. If you use it to store VMs for ESXi, it's synchronous.Bummer. So, the synchronous writes are generally slower than asynchronous writes? What's the default settings provided by TrueNAS? How much is the impact between these two in terms of speed?
I found a metadata special vdev beneficial but I am here in a corporate environment with 10 people using the NAS concurrently, all for time machine backups. If this is just for you personally I doubt there will be much of a benefit, but I don't have hard numbers.BTW, as it will be a Time Machine and rendering output directly to this NAS box, do you think it would be beneficial to use a metadata drive? As Time Machine will have a lot of directories and i wonder if it will make it difficult during the restore time.
Got it!Yes. The default is asynchronous for SMB and synchronous for iSCSI. I don't know from the top of my head for NFS what the default is. If you use it to store VMs for ESXi, it's synchronous.
Got it!As for the impact: factor of 10? As I wrote "an order of magnitude".
Hmm. I see. There will be three users in total. Not that much. Do you think it will make any benefit when adding the metadata drive? Currently, testing the newly build NAS box and the directories takes times when searching and sometimes it just takes longer to calculate the number of files (Get Info). So, if it makes any real difference, it would be cool to add it up. Honestly, i had never set it up but when searching for the issue, i got it to know on this forum what it is used for!I found a metadata special vdev beneficial but I am here in a corporate environment with 10 people using the NAS concurrently, all for time machine backups. If this is just for you personally I doubt there will be much of a benefit, but I don't have hard numbers.
Got it. I'll see if it fits my budget. If it does, I'll really consider buying optane due to the endurance and latency factor. Or Optane will be just overkill for a metadata drive? Unlike SLOG and L2ARC, where Optane is highly recommended, I'm not sure what's the general recommendation for the metadata drives. Also, how do i calculate what capacity would i require for the metadata drive? Regarding the redundancy, would it be really okay to use 2xDrives for the metadata? As I've generally seen 3xDrives normally on the forum. I've currently 8x10TB Drives and it has 10GbE network and i get the full speed. I might consider upgrading it to 10x10TB Drive anytime soon or it could be 10x14TB or 10x16TB.You can buy two or three of some "prosumer" SSDs and use these in a mirrored vdev for metadata. No need to go Optane for that. So it's not that big of an investment even if the benefit should be marginal. Make sure to use enough redundancy. Capacity on the other hand is not an issue, so small & reliable > large capacity.
I remember MacOS using syncwrites with SMB as default though.Yes. The default is asynchronous for SMB and synchronous for iSCSI.
That might explain the perceived performanceI remember MacOS using syncwrites with SMB though.
Hmm. Seems like i need more learning on it!There is no such thing as a snapshot drive. Snapshots are simply states of the ZFS at a certain point in time that are not deleted but kept until you manually delete them or roll back.
Surely. Not in a rush. I'm still testing and exploring the NAS and related features. If you find time, please answer. Really appreciate your participation. Helped me to learn new things today! KudosDon't have the time right now to answer everything. You might want to read the ZFS primer. And hopefully someone else will also step in.
Yes, I'm aware of it. Been a Mac user since a long time. But what i meant is the Snapshot feature of the ZFS/TrueNAS is same as the Time Machine?Time Machine creates a snapshot for each single successful time machine backup, BTW.
Umm, where i can change this settings? On the Windows side, using the same hardware, same NAS and network, i get like 850-900MB/s and on Mac side, it's like 250-300MB/s max.I remember MacOS using syncwrites with SMB as default though.
Hmm. I think so. I'll testing using older Macs just to check. As when i checked, a lot of people said that changing signing_required=no can fix it. Haven't tested it yet. Will have to backup and then check if that really works. Me using Mac since last 10yrs :)That might explain the perceived performance
But then I never felt the need to complain and I have been using a Mac for the last two decades. I'll have to check.
Go ahead and purchase these anyways. Then you can deliver them to me for extensive longterm testing.Thanks man. I was going to buy like 2xOptane 905P for that. I got few $$$ saved :)
Sounds great :)Go ahead and purchase these anyways. Then you can deliver them to me for extensive longterm testing. I'll let you know if they can work a SLOGs. I like to help out my fellow community members.
Not a fair deal. I get you the drives for testing. You keep the drives. I think you can pay the shipping cost ;)(You have to pay for shipping costs.)
Not exactly correct; Macs will use it for TimeMachine operations but not most things; TimeMachine performance though has much more to do with the low priory assigned to it. Since most macs are going to be operating over wifi I would suggest an SLOG not for performance centric reasons but data consistency biased ones (faster sync writes is useful when wifi might suddenly cut out for a moment or two).I remember MacOS using syncwrites with SMB as default though.
2 of these would be more than enough for an SLOG for TimeMachine use: https://www.newegg.com/intel-optane-ssd-p1600x-58gb/p/N82E16820167488 (much less expensive).Thanks man. I was going to buy like 2xOptane 905P for that. I got few $$$ saved :)
Any idea why the Read and Write speeds are much slower on the Mac side? Its quite fast on the Windows side.Not exactly correct; Macs will use it for TimeMachine operations but not most things; TimeMachine performance though has much more to do with the low priory assigned to it. Since most macs are going to be operating over wifi I would suggest an SLOG not for performance centric reasons but data consistency biased ones (faster sync writes is useful when wifi might suddenly cut out for a moment or two).
As stated in the post, the NAS will be used mainly for Time Machine backup and the video will be rendered directly to the NAS. It has 8x10TB HDD and 10GbE network. Will SLOG be beneficial for my use case? Will it help me to accelerate the write speeds?2 of these would be more than enough for an SLOG for TimeMachine use: https://www.newegg.com/intel-optane-ssd-p1600x-58gb/p/N82E16820167488 (much less expensive).
